Author Topic: Dash Pad Trim  (Read 2689 times)
Offline ChrisV289
Dash Pad Trim
« on: June 28, 2010, 09:18:03 PM »
Does anyone sell the clips that go behind the dash pad trim or know how many there are suppose to be really?  My windshield is getting replaced this Saturday and I took the trim off in advance and noticed there are only 2 metal clips attached to the passenger side only.  There are 6 spots total where there could be clips.  65 SJ fastback
2009 V6 Mustang Coupe
Re: Dash Pad Trim
« Reply #1 on: July 01, 2010, 04:27:40 PM »
Not following exactly.  Are you talking about the windshield molding clips?
Offline ChrisV289
Re: Dash Pad Trim
« Reply #2 on: July 01, 2010, 06:06:48 PM »
These clips:
I only have two if them and they are only behind the passenger side dash pad trim
Re: Dash Pad Trim
« Reply #3 on: July 01, 2010, 07:40:48 PM »
I've only seen those on'67-up.
Offline ChrisV289
Re: Dash Pad Trim
« Reply #4 on: July 01, 2010, 07:56:44 PM »
Hmm interesting....i know it's not the original windshield.  It was replaced by either the first or second owner with a carlite blocked lettering windshield with a date code of 4E.  Do you think someone added just the 2 clips?
Re: Dash Pad Trim
« Reply #5 on: July 01, 2010, 09:18:42 PM »
They're really not necessary on a 65-66 as the molding fits up pretty tight.  The dash pad angle is sharper in 67-8, which is probably why they were used... albeit, I have only found them in the center position.
Offline buckeyeresto
Re: Dash Pad Trim
« Reply #6 on: July 02, 2010, 07:22:37 PM »
Those are very hard to find on mustangs.  I have taken apart alot of early mustangs and the cars with the dash trim never removed usually contain those clips their is a clip for every screw.  If they are gone the dash or winshield has been removed or leaked at sometime because they are a total pita to get back in.  If some are missing the dash has been tampered with sometime in their life time.  My 66 K Coupe for San Jose I have been working on contained all the clips and even 140 or number 01 have the clips
Re: Dash Pad Trim
« Reply #7 on: July 03, 2010, 01:11:33 AM »
They're not something that would fall off easily upon removal or an owner deem unnecessary and simply discard.  On the cars that I have seen them on, I have only ever found one clip, which was in the middle.
Offline kutzoh
  • Gold Level Subscriber
Re: Dash Pad Trim
« Reply #8 on: July 03, 2010, 09:34:38 AM »
For what its worth, I'm using Osborn's Body Assembly Manual for 64 1/2 Mustangs and I don't see the clips called out, just screws.
Greg
Offline ChrisV289
Re: Dash Pad Trim
« Reply #9 on: November 07, 2010, 10:06:46 AM »
I was looking through some books and I did find a mention of these clips in two places.  One on page 22 of the Mustang interior restoration guide by Art Trantafello.  I guess they are called support brackets (part #65045c72).  There is a pic on the bottom of the page showing the diagram.  They are also shown in the 64.5-73 restoration book diagram on page 92.  Very small but you can see it there.
Re: Dash Pad Trim
« Reply #10 on: November 07, 2010, 10:26:28 AM »
Your car, install them if you like.  Not typically found on 65-66 cars as mentioned before.
