Author Topic: 70 Metuchen - Hood Weatherstrip on Radiator Core Support Attachment  (Read 1202 times)
Offline Rbisch4
What was used for Metuchen for the hood weatherstrip?  Mine original support had large enough holes that were not staple holes.  I used screws to secure.  Curious to see what would be correct for Metuchen 10/08/69 build date.
« Last Edit: August 16, 2016, 08:35:10 PM by J_Speegle »
1970 Mach 1 351 4V 4spd Metuchen Built
Offline Vcode
Re: 70 Metuchen - Hood Weatherstrip on Radiator Core Support Attachment
« Reply #1 on: August 16, 2016, 01:04:44 PM »
My 5/69 Metuchen has staples.
« Last Edit: August 16, 2016, 08:35:28 PM by J_Speegle »
« Reply #2 on: August 16, 2016, 08:57:09 PM »
Wish I had more examples (seems more early than late cars) appears there is a pattern to method used to attach them
Posted each below for your, review,  use and application if you choose to. Stayed with Mach I's so that the confusion of the longer/wider seal would not confuse the discussion and I also had more Mach's with AC and the seal :)
0T05R1066xx - Screws
0T05R1082xx - Screws
0T05R1100xx - Screws
0T05H1199xx - Staples
0T05H119xxx - Staples
0T05R1453xx - Staples
Offline Rbisch4
« Reply #3 on: August 16, 2016, 09:11:48 PM »
Thanks.  Good to see I did it right.
