Author Topic: 65-67 group 22 Autolite Battery Discussion  (Read 22880 times)
Offline Andre Romein
Re: 65-67 group 22 Auolite Battery Discussion
« Reply #105 on: February 16, 2022, 02:50:36 PM »
So, this is one of the empty display cases they once had?
Do you have any other images or a description of the processes you used?
« Reply #106 on: February 16, 2022, 02:53:30 PM »
i cannot open his pic. message says i need more memory on my pc........don't have it. can it be resized?
Offline aaatp
« Reply #107 on: February 16, 2022, 03:16:44 PM »
Now that was awesome!!
« Reply #108 on: February 16, 2022, 04:37:28 PM »
Looks great in the pictures. Thought someone would figure out how to use 3D printing to make it work. The printing directly on the core is interesting and makes it somewhat limiting but seems to create a better end product
Going to merge this together with the main battery discussion thread since it relates to more than just 65 and will also show the progression through all the points, details and progress over time. That's over in the PARTS section
« Last Edit: February 16, 2022, 04:44:32 PM by J_Speegle »
« Reply #109 on: February 17, 2022, 02:08:35 AM »
Great job .Best that I have ever seen. +1 on no paint on Autolite letters top and sides.  In its current configuration with the red caps it represents the optional heavy duty battery. Keep in mind that given information in the service specifications manual that the heavy duty 55 AH battery would use the 55 amp red stamped alternator and corresponding C5TF yellow stamped regulator.
i saw that this one is considered as a real battery and referred as a true 65, if it's not then how come?
« Last Edit: February 17, 2022, 02:13:10 AM by Andre Romein »
« Reply #110 on: February 17, 2022, 03:02:11 AM »
That's a group 22 battery, it normally would have yellow caps.  The red lettering was probably added or may have been a detail unique only to a service replacement battery.  Below is a pic of an assembly line 22F.
Offline upsetter
« Reply #111 on: April 05, 2022, 07:19:49 PM »
I've been reading from this website for maybe four years and learned a lot. Probably already forgot some things. I'm as green as the battery caps you are talking about BUT thought it was time to add. I have a connection with a Nascar team and they have FOUR 3D printers and I've already confirmed from my connection, he knows how to work them and can use them. They are backed up. They make parts all the time. He did request a model. Would 24F one from Virginia Classic Mustang do? Just trying to help our situation.
7T02S173XXX  GT  built: 12/28/66
« Reply #112 on: April 05, 2022, 07:27:40 PM »
The cost to 3D print an entire battery would be too much to make it feasible.  Most 3D printing will leave lines in the surface, which would require additional effort to smooth out and it still would not look right.  Maybe there are some high end 3D printers that can print smooth?
« Reply #113 on: May 23, 2022, 11:23:48 AM »
I found this battery to fit inside the case with plenty of room for the cables. Specs look good for cranking up an engine too.
The case (bought from Va. Classic a few months ago) has terminals to bolt any connections onto as well.
Now, just to figure out how I wish to mimic the proper top details, closest simulation I have found so far is a yellow lettering label that comes on a Battery topper (fits into the location where the reproduction case has a raised surface for the 68-up style warranty decal).
By the way, NPD NOW CARRIES THE EMPTY SHELL CASES!
"Braille Battery B2618: Advanced AGM Lightweight Racing Battery 18.5 lbs - JEGS High Performance" https://www.jegs.com/i/Braille+Auto/147/B2618/10002/-1?gclid=CjwKCAjw4ayUBhA4EiwATWyBrpcjuaLjjjjWZcMiR6zlDg7llVS7j-N0Ogfc3hZe9PvVnIArnzJMPRoCg9EQAvD_BwE
« Last Edit: May 23, 2022, 11:34:06 AM by 67gtasanjose »
« Reply #114 on: May 23, 2022, 02:38:26 PM »
what time frame battery are you looking to replicate?
« Reply #115 on: May 23, 2022, 03:22:05 PM »
67
« Reply #116 on: May 23, 2022, 04:22:41 PM »
FYI 65-67 group 22 batteries look the same . It is the 68 and up that look different.
« Reply #117 on: May 23, 2022, 06:24:54 PM »
I realized just now that I had commented in a Group 22F thread. I am trying to build a 67-older Group 24F, red cap battery. The recent post of 3D printing of the raised yellow letters (on a 24F empty case) within this particular thread, is what pulled me here to comment on the Race Car battery I purchased.
« Reply #118 on: May 23, 2022, 08:26:06 PM »
You probably got a few people excited that a 22 was available. 65-67 group 24 look the same case wise. 68-up look different. Good info for others on the race car battery.
Offline 65IVYGT
Autolite Group 24 Battery
« Reply #119 on: July 11, 2022, 07:43:48 PM »
Does anyone have a photo of an early (64-66) Group 24 (not 22) Autolite battery...particularly the top. I'd like to compare it to the repos available. I've search the library...but don't see that specific picture (unless I missed it).
Thank you.
65 GT Coupe, SJ:5/17, Factory Air and PS, 4-Speed, Ivy Green, Pony Interior.
