Author Topic: 66 - Glove box restored  (Read 2517 times)
Offline Josep
« on: August 12, 2016, 10:59:54 AM »
Hi mates,
I was waiting for some stuff to restore my glove box, and they finally arrived so this morning I have done the restore.
I was missing the Emergency flasher switch and the light. I wasn't sure if I had the correct harness under the dash to connect everything, but after a close inspection, it was there.! The original harness going to the switch was a little wound around other cables, but have unwound it and when tested, all 4 turn lights worked.! So job done.
Then, I have fixed the light, and again the pigtail connection needed was there, so easy job, just connect and go.! I have also replaced the screws that holds the liner into place, I think they are now correct, or at least they sold me like concours correct.! Guess my whole glove box is close to concours now.! One thing less to worry about..
Here are some pics.
« Last Edit: August 14, 2016, 05:33:19 PM by J_Speegle »
Offline rrenz
Re: Glove box restored
« Reply #1 on: August 12, 2016, 08:06:19 PM »
I just finished mine as well. Used those same black screws.. I also hope they are correct. I was in the same boat. i happened to find an emergency flasher switch at carlislie a couple years ago and just picked it up. I later found my harness wrapped around some other wires up in the dash.Hooked it up and all four flashed. With how everything in this hobby seems to fight back so hard i was dumbfounded that the stupid things started blinking the first freakin time.
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Offline Hipo giddyup
« Reply #2 on: August 13, 2016, 06:46:43 PM »
 Looks very nice, job well done !
Offline Josep
« Reply #3 on: August 13, 2016, 07:57:49 PM »
thanks Hipo.!
rrenz, yeah! It's amazing when you connect a thing in a 50yrs ol' stuff and works at first shot.! Satisfaction is what you feel.!
Josep
Re: 66 - Glove box restored
« Reply #4 on: August 14, 2016, 05:34:00 PM »
Couple of pictures from a unrestored car for details
Offline Josep
« Reply #5 on: August 14, 2016, 06:19:32 PM »
Jeff, thanks for the pics I note a couple of details.
My eyes are not used to discover those small details, but I can see the screws are "Phillips" style while in mine are not. Didn't find here the right ones, but give me some time.!
Then I also see the position of the "tyre pressure" decal to be centered while mine is a bit on the right.
Maybe I'm missing others sorry.
Josep
PS: OK, the screw that holds the cable to the lid is also black. The set was 7 black screws and I think it has 8 holes.!
« Reply #6 on: August 14, 2016, 06:24:00 PM »
Purpose was just to help out and provide you with some addition access to a picture. Don't worry about the decal - it was a quick rapid application and as long as it was stuck "about there" I'm sure it reflects how some were applied. It all takes time and we often focus on one detail will overlooking another - its just being human :)
Offline Josep
« Reply #7 on: August 14, 2016, 06:27:21 PM »
And I really thank you very much your help indeed.!! That helps me looking for the most accuracy posible for my car.!! Alright for the decal, thought it may be placed in some specific place  :)
For the screws, maybe it would be a good idea from NPD to make the packages of 8 screws instead of the 7 they are selling now. See that 8 is what is needed for the glove box.!
Thanks again.!
Josep
« Last Edit: August 14, 2016, 06:46:56 PM by Josep »
« Reply #8 on: August 14, 2016, 11:15:46 PM »
Often you will see another type/style attaching the limiting cable to the dash rather than the phosphate flat head version
While you looking at hardware you might want to find some machine screws for the emergency flasher bracket rather than the bolts you have ;)  If you wish to
« Reply #9 on: August 14, 2016, 11:39:20 PM »
The two screws for the 66 emergency flasher switch bracket are 54505-S2, 10-24X1/2 pan 3/8 dia, Philips; the nuts are 34655-S2, 10-24 hex 3/8 drive, with an attached external tooth lock washer.
The two door cable stop screws are 379203-S2, 8-18x1/2pan with a shoulder. (A wavy washer was used in 1964-65 only.)
A picture may be worth a 1000 words, a part number describes the item completely.
Offline Josep
« Reply #10 on: August 15, 2016, 05:06:52 AM »
Quote
Quote
Yes Jeff and Jim, many thanks for the detailed info about the nuts and screws. As I mentioned before, I didn't find the right ones here, but will look for them in other stores around, sure I will find something. If not, there's always the chance to order them from the US, when I have a larger order to post. Thanks guys.!
Josep
