Author Topic: Horn Problem  (Read 8935 times)
Re: Horn Problem
« Reply #15 on: July 06, 2010, 10:42:56 PM »
Horn attaching bolts were phosphate/oil.
There are some variations in the later horns.  Going from memory, but know that at least some '68 had date codes stamped into the metal.
Also some variations in the ink date stamps, but that is probably worthy of another thread.
Offline Pete Bush
Re: Horn Problem
« Reply #16 on: July 08, 2010, 06:38:30 AM »
Thanks, Charles. I did some searching of the archives here, and there's been some interesting discussions on phosphate finishes.
I see where Midway Products sells a cold phosphate product: KG K-Phos 4000. Seems like an easy, economical way to handle the small bolts, and get an introduction to the coating process. Have you had any experience with the product?
Re: Horn Problem
« Reply #17 on: July 08, 2010, 10:48:12 AM »
I haven't tried the cold phosphate solution.  If you do, let us know how it goes.
Offline macdude67
Re: Horn Problem
« Reply #18 on: July 09, 2010, 08:41:57 PM »
Hey Pete how are the horns? If your still having problems this might help. You mentioned using a meter and reading current at the jack? What you were reading was voltage. You can have a full 12.5 plus volts at that jack and have good horns and still have an issue.
Offline Pete Bush
Re: Horn Problem
« Reply #19 on: July 10, 2010, 06:35:08 AM »
Macdude,
I check voltage at the jack (12v), and continuity through the horns (none). Is there another test I should have performed?
Offline macdude67
Re: Horn Problem
« Reply #20 on: July 10, 2010, 11:59:47 AM »
someone mentioned it but i didn't see a repost on it, can you make the horns work by connecting them directly to a battery by placing the horn bracket on the negative post and connecting the positive post to the horn terminal with a jumper wire?
Re: Horn Problem
« Reply #21 on: July 10, 2010, 11:04:18 PM »
Yes, they can be tested like that.  Just be careful!
