Author Topic: Turn signal switch ID  (Read 1041 times)
Offline Oz390
« on: July 27, 2016, 07:31:39 PM »
Have an Autolite box w/C8ZZ-13341-A ink stamp. Someone marked it "C8SZ-A" in marker pen.
The harness has a purple FoMoCo tag w/C8AZ-13B302-C1 on it.
No way to tell if the harness and box were originally together, or if the part was reboxed.  Web searches did not help to ID the C1 part.
I think this is a '68 tilt wheel switch, but am not sure. Can anyone confirm?
8R03S : 76A I 2A 15M 72 5 U
Offline Andrew@MagMustangs
    • MagMustangs
Re: Turn signal switch ID
« Reply #1 on: July 30, 2016, 01:08:25 AM »
Numbers on box are for 68 Fixed Column. Number on wiring tag is for a Ford Full Size which did not have Tilt-Away in 68(Except T-Bird).
Offline Oz390
« Reply #2 on: July 31, 2016, 07:56:13 AM »
Thank you.
Offline WT8095
  • Dave Z.
« Reply #3 on: July 31, 2016, 02:24:33 PM »
Are you sure that tag says "C8AZ-C1"? Any chance it's "C8ZA-C1"? (reverse the Z & A?)
Dave Z.
