Author Topic: 70 Ported Vacuum Switches (PVS) Distributor Vacuum Control  (Read 15939 times)
Re: 70 Ported Vacuum Switches (PVS) Distributor Vacuum Control
« Reply #30 on: December 29, 2017, 03:25:58 PM »
fomoco  vs ford
« Reply #31 on: December 29, 2017, 08:29:37 PM »
... and a 12 K 68 just to even things out.
« Reply #32 on: May 09, 2018, 10:31:06 AM »
I found a "G" part - full code "1 G 70" the other day.  I saw K and H discussed here, but no G so I figured I would add this to the equation.
« Reply #33 on: May 09, 2018, 07:01:39 PM »
John - Thanks  Don't recal every seeing a G. What we suspect was the suppliers code.
Thanks for posting a picture
« Reply #34 on: May 09, 2018, 11:11:49 PM »
Odd dont recall  G  maybe a misstamp or something & i have had  many of these over the years from all makes of fords in yards & dont remember a G  but will look closely as i got about 50 left here.
Offline 1970 Snake
« Reply #35 on: May 11, 2018, 09:42:05 AM »
I noticed the post and followed it though and see you have confirmed the D0AE-A PVS was used as early as Aug/Sept 69 on 1970 engines.
I would like to confirm that my 1970 428CJ R-code Mach1 Dearborn built on Sept 4, 1969, also has a D0AE-A with 7-H-69 PVS
I am curious what do the 1D2 markings on the opposite side define??
I bead blasted it and probably the wrong thing to do, is there any way to get the bronze shine back??
« Last Edit: May 11, 2018, 09:44:15 AM by 1970 Snake »
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Offline Anghelrestorations
    • Anghel Restorations
« Reply #36 on: May 11, 2018, 11:54:13 AM »
John,
In the picture you posted above with the G stamp does the switch on the bottom actually have holes drilled in it, or is that just a shadow?
Marcus Anghel
www.anghelrestorations.com
« Reply #37 on: May 11, 2018, 02:19:27 PM »
John,
Looks like it has dimples. Have those on many of the ones I've found over the years
« Reply #38 on: May 11, 2018, 10:25:31 PM »
The brass base with have to be polished and then appropriately dulled back down . The ported body is made of the same zinc based pot metal as a Holley Carburetor body. Without going into a lengthy tutorial you would refinish it the same way you would the carb body.
Offline 1970 Snake
« Reply #39 on: May 13, 2018, 05:18:21 AM »
Thanks Bob, will need to figure out how to polish without damaging the finish on the non brass housing and polish wheel hooking on to the nozzles,
I asked the question about the 1 D 2 nozzle markings and assume those define the hose connections, but what are they?
1 = ??
D = Distributor
2 = ??
« Last Edit: May 13, 2018, 05:24:46 AM by 1970 Snake »
« Reply #40 on: May 13, 2018, 01:11:41 PM »
I've had some of those bowl type vibration cleaners/polishers. When things are set up I have one set up plastic, bake-lite and other parts in to clean and buff them. Just ground up corn hush (you can buy it bulk as bedding for small mammals) with some fine buffing compound added. Put caps over the ports in the part and leave them for a few hours and they turn out well (PVS) and are ready to be recoated for the upper section. The polished surfaces will dull with exposure over some time
Offline 1970 Snake
« Reply #41 on: May 13, 2018, 09:24:23 PM »
Awesome great detail, thanks Jeff will give it a shot.
Any comments on the number/letter coding by the hose nozzles??
« Last Edit: May 13, 2018, 09:26:57 PM by 1970 Snake »
« Reply #42 on: May 13, 2018, 10:22:19 PM »
author=1970 Snake
Any comments on the number/letter coding by the hose nozzles??   That information is in the Shop Manual, for the 69 anyway, and varies by engine and accesories.  Brian
Offline sah62
« Reply #43 on: May 14, 2018, 09:34:35 AM »
1 = ??
D = Distributor
2 = ??
I have that described here: https://www.428cobrajet.org/id-dist-vac-valve
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
« Reply #44 on: May 14, 2018, 07:05:57 PM »
On pre 70 engine applications the routing of the ends is illustrated in the engine vacuum diagrams shown in the Library section of the site by year.
