Author Topic: Replacing tubular rivets in 66 grille  (Read 1644 times)
Offline sgl66
« on: July 22, 2016, 03:38:38 PM »
I need to replace 2 rivets. I have the correct tubular style, what are people using to crimp them?
Re: Replacing tubular rivets in 66 grille
« Reply #1 on: July 22, 2016, 03:59:25 PM »
I use one of these, bought back when it wasn't as expensive. You also need two dies, one domed for the top of the rivet, one with a "pin" for the bottom.
http://rivetsonline.com/to-to-888-15.html
http://www.rivetsinstock.com/
Offline sgl66
« Reply #2 on: July 22, 2016, 04:17:38 PM »
Thanks Jim,
I'm only doing 2 rivets so looking for a way to MacGyver it if possible
« Reply #3 on: July 22, 2016, 08:16:58 PM »
I made this tool for installing tubular rivets on my 67 Mustang Grille.
Same tool will work on your 66.
Use a 3/16 steel ball-bearing under the die attached to the threaded shaft to prevent the die from spinning. The tool works great.
« Last Edit: July 22, 2016, 08:20:27 PM by 67gtasanjose »
Offline sgl66
« Reply #4 on: July 24, 2016, 12:36:23 AM »
Thanks for the pictures. I heading down a similar path.
