Author Topic: Radiator Support to Hood Seal Clips  (Read 2096 times)
Offline Rainier42
« on: July 09, 2016, 03:39:53 PM »
Anyone have a source for the radiator support to hood seal clips?  NPD used to carry but they are out of stock and will no longer be carrying them.
Re: Radiator Support to Hood Seal Clips
« Reply #1 on: July 09, 2016, 04:35:14 PM »
Which ones? There were more then one used . Can you post a picture of the ones you know you need? For example the gas tank sender wire clip used on 65-68 was a variety that has been observed used at some plants in some situations .
Offline Rainier42
« Reply #2 on: July 09, 2016, 04:36:48 PM »
« Reply #3 on: July 09, 2016, 05:59:06 PM »
Looking for clips on this order: https://www.npdlink.com/store/products/clip_kit_retainer_5-196284-125.html
Those would be the ones we see used at San Jose in 69-70 typically. Not used IMHO at the other two plants/cars
Offline Rainier42
« Reply #4 on: July 09, 2016, 06:09:49 PM »
Any sense of clips used by other plants?
« Reply #5 on: July 09, 2016, 07:03:56 PM »
re read reply #1 . The clips mentioned were sometimes seen on Dearborn car including 69/70 instead of the more prevelent staples.
« Reply #6 on: July 09, 2016, 07:15:31 PM »
Yes - they are discussed and pictures shown in at least four other threads.
Search is your friend - used 69 radiator seal clips. Other words might produce even more info ;)
http://www.concoursmustang.com/forum/index.php?topic=838.msg4287#msg4287
http://www.concoursmustang.com/forum/index.php?topic=4616.msg25810#msg25810
http://www.concoursmustang.com/forum/index.php?topic=11627.msg70032#msg70032
Discussion of the 69 style
http://www.concoursmustang.com/forum/index.php?topic=707.msg85852#msg85852
Offline 7Lscjracer
« Reply #7 on: July 09, 2016, 07:21:40 PM »
Re non San Jose clips
http://amkproducts.com/Catalog_PDF/138-150.pdf
A common electrical clip as pictured on page 145
I think it was the half plasti-dipped ones as opposed to the plain ones (4th and 3rd on page)
I posted about this years ago and right after, they started showing up on eBay used for $40 a set or some nonsense, gimme a break!
I have some in my junk box if you need them.
« Last Edit: July 09, 2016, 09:30:17 PM by 7Lscjracer »
Bought May '81, sold Sept '20
« Reply #8 on: July 09, 2016, 08:10:10 PM »
Looking at the MPC (May, 75 ed) under the seal called out in the 70 Mustang Body Assembly Manual, page 17 (that and a couple of other pages are missing from the 69 Body Manual), C4DB-16A238 - factory, C4DZ-16A238-A - service, it shows the application as "69 390 4V" and "70 200 I-6, 428CJ". However, under full size Ford is a referral to base number 8349 which is another seal group, mostly full size Fords, T-Birds, 70-71 Torino (all engines) and 71-73 Mustangs (all engines). The key here is this seal group, 8349, list the clip 371141-S as being used - only for T-Birds and the Torinos.
That's what Ford service lists, and we know Ford factory is sometimes different. This much can be gleaned from the above - the clip was used for radiator seals. How or why Mustangs got the clip is open. The stapler being broke is a very good reason.
