Author Topic: 65 K Code - Oil Pressure Sending Extension  (Read 1006 times)
Offline Kmurf2007
« on: July 09, 2016, 09:52:53 AM »
Can someone confirm for me if a 1965 Mustang (Dearborn Nov 64) with a K Code Engine uses an Oil Pressure Sending Extension or if the Oil Pressure Switch just screws directly into the block.
Thanks for your response
1965 K Code Convertible - Built Nov 64 Dearborn
2007 Shelby GT500 Convertible
Re: 65 K Code - Oil Pressure Sending Extension
« Reply #1 on: July 09, 2016, 10:20:18 AM »
no extension used in that application. only the larger sending unit requires it.
Offline Kmurf2007
« Reply #2 on: July 09, 2016, 10:41:19 AM »
Thanks for your support.
I want to make sure I put it back together correct.
Kevin
« Reply #3 on: July 09, 2016, 11:46:07 AM »
+1
The usual scenario on all small blocks:
Idiot light = small sender (no extension)
Gauge = Large "Bell" sender (requires extension)
