Author Topic: Radiator Tag Codes  (Read 4795 times)
Offline ChrisV289
Radiator Tag Codes
« on: July 06, 2016, 09:35:24 PM »
What application would the following radiator codes be for?  I've seen M2, Y2, and Z2 but what about:
F2
U2
D2
2009 V6 Mustang Coupe
Re: Radiator Tag Codes
« Reply #1 on: July 07, 2016, 02:04:56 AM »
F2
U2
D2
If referring to C4ZE Don't forget about the infamous G2 . The C4ZE U2 is 6cyl maybe others are too . if C7 or C8 prefix then the applications could be V8
« Reply #2 on: July 07, 2016, 04:50:36 PM »
Have seen a
D2 in a 65 & 66 T code
U2 incorrectly in a late 66 C code (4 64 date) so don't know where it came from
But do have a sighting of a
B2 in an early 65 San Jose F code  (C4ZE-B2   6 64)
B2 in a 65 San Jose T code  (C6ZE-B2  on a tag with  11 65 )
Offline Bartman
« Reply #3 on: July 14, 2016, 02:33:48 PM »
Don't forget the C4ZE 8005 G1 which my my Aug 64 car has.
Offline Bartman
« Reply #4 on: July 14, 2016, 02:43:35 PM »
Sorry for my ignorance "DEP" stands for what?
« Reply #5 on: July 14, 2016, 02:50:39 PM »
dearborn engine plant
« Reply #6 on: July 14, 2016, 04:26:53 PM »
Fine, all well, and good - not. How about a definitive chart: years; plants; engines; options; radiator part numbers. That's all that really matters.
Offline 66RavenGTCoupeAgain
« Reply #7 on: July 22, 2016, 04:47:35 AM »
I didn't know that! I thought DEP was the suppliers actual name Like DEP inc or something.
Thanks.
66 Metuchen NJ  GT Coupe
Raven with Deluxe Black Int 289 A Code C4 PS Tinted Windows (Green) Dealer installed Rear Speaker
6T07A1612## Dec 65 Build
65 San Jose CA Convertible Rangoon Red with White Int and Power Top with plastic rear window 289 C Code C4 PS PB AC Fog Lights
5R08C1496## Oct 64 Build
« Reply #8 on: July 22, 2016, 05:08:21 AM »
This is from Kevin Marti's "The Mustang and Cougar Tag Book".
Offline hopeto
« Reply #9 on: April 25, 2019, 06:17:52 AM »
Should a Feb 6, 1965 San Jose K Code car have a G2 or a Y2 tag? Thanks
Original one owner 84 GT Convertible with 1800 miles. 65 Silver Smoke Gray K Code GT Coupe - 65 Cyclone - 67 Vintage Burgundy K Code GT Coupe.  1970 Calypso Corral Boss 302 - 2012 Yellow Blaze Boss 302.
« Reply #10 on: April 25, 2019, 11:44:47 AM »
If a 4 speed then G2 would be typical for that time frame.
« Reply #11 on: April 25, 2019, 11:49:15 AM »
It should be noted that the code would not be on a metal tag like picture of Marti book on a 65 SJ car but instead the code was made into the radiator top tank (pressed in). The metal tags did not come into use until early 66 production at SJ.
« Reply #12 on: April 25, 2019, 05:18:30 PM »
According to my collection of data your car falls into the change over period and unfortunately don't have any current examples real close to yours.
Have a bunch of G2 radiators made (dated) in Feb 65 and the last Y2 I have records for is dated Dec 64.
Other non K code Mustangs with projected build dates like yours I have Dec 64 and Jan 65 radiators recorded for them
Offline Maksim27
« Reply #13 on: April 07, 2020, 05:49:19 PM »
Is this radiator that I have an aftermarket.  It has a tag, but doesn't have Ford Numbers.
I'm trying to find a radiator that matches my San Jose build code Jan 11 1966.    200 and C4
« Reply #14 on: April 07, 2020, 05:55:13 PM »
Responding to this in the other thread where you posted also. Place an ad in the wanted section once you figure out what you specifically need for best response. members are often reminded not to respond to mentioned wanted posts in the discussion area to keep the focus on the thread and use PM's instead. Don't need half a dozen "I've got that" posts in a discussion thread ;)
« Last Edit: April 07, 2020, 05:57:51 PM by J_Speegle »
