Author Topic: Firewall Grommet Question  (Read 2311 times)
Offline bjf1992
« on: July 06, 2016, 05:33:34 PM »
Is there a grommet that goes in this location? The body plug kit I purchased doesn't have one.
Car built April 2nd 1969 Dearborn
1969 Q Code Standard Cougar Convertible P/S, P/B, A/C
Pastel Grey, Lt. Blue interior Black Top
Built April 2nd, Dearborn
1969 Mustang Sportsroof
September 68 Build date, Metuchen
Re: Firewall Grommet Question
« Reply #1 on: July 06, 2016, 07:14:34 PM »
Believe there was just a lump of dum-dum shoved in it and flattened some what to seal it off
« Reply #2 on: July 06, 2016, 07:31:25 PM »
Here are two original examples - the dum-dum/sealant can be hard to make out
« Reply #3 on: July 06, 2016, 10:27:36 PM »
Sort of related ?  I broke the grommet/plug that goes in the hole in the firewall/cowl just above the export brace.  How do I identify or get a replacement ?  The seat floor plugs are to big.  Thanks,  Brian
« Reply #4 on: July 06, 2016, 11:04:31 PM »
That is approximately a 1-1/4 inch hole from my measurement. Body plugs in that size are available individually.   ;)
Offline bjf1992
« Reply #5 on: July 07, 2016, 10:54:21 AM »
Cool! Thanks again
« Reply #6 on: July 07, 2016, 06:47:46 PM »
[quote author=krelboyne
Yes thank you Scott.  I guess your packing up my, part # 27544, body plugs about now ?  Do you think you could do a test fit ?  Thanks,  Brian
« Last Edit: July 07, 2016, 06:53:31 PM by Brian Conway »
« Reply #7 on: July 08, 2016, 12:58:12 AM »
You want 377936-S. It's for a 1 1/4 inch hole.
« Reply #8 on: July 08, 2016, 02:54:46 PM »
Thank you Jim for the part number.  I suppose if I had looked in the ' library ' it would be there ?  Some time back we had this discussion but I was unable to SEARCH it out.  Brian
« Reply #9 on: July 08, 2016, 04:30:11 PM »
It's there, "sort" of - and I mean that as pun and function. If you down load either 69-70 spreadsheet from the Forum's Library, you can "sort" it by DESCRIPTION and isolate "Plug,Rubber". Looking at the Size/Description will give you the hole size and part number. I could not find any Ford documentation to verify the plugs sizes so I measured the plugs. The irony is that plug is used on the cowl above the firewall in the center.
