Author Topic: 67 Spring in ignition switch?  (Read 1245 times)
Offline 67350#1242
« on: July 01, 2016, 03:27:50 PM »
Does anyone know if there is supposed to be a small spring in the ignition switch (67) between the lock cylinder and the slotted portion that actuates switch positions?   I have read somewhere that this spring puts pressure onto the switch plates to prevent intermittent contact?
It would be exposed once the switch cylinder is removed - and should be down in the center of the switch housing held in with white grease.
I'm trying to track down a phantom problem with intermittent cranking (intermittent actuation of starter solenoid).
Any help would be appreciated - thanks, Kurt.
« Last Edit: July 05, 2016, 05:41:53 PM by J_Speegle »
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
Re: Spring in ignition switch?
« Reply #1 on: July 02, 2016, 12:16:14 AM »
I would not be surprised if the problem is the solenoid. Have you tried another one? I have had several switches apart and there is not a spring under the cylinder.
  Marty
Offline 67350#1242
« Reply #2 on: July 02, 2016, 10:49:28 AM »
I found this picture from Mustang Monthly article showing a 65/66 switch with the spring.   Since 67 is similar, I thought it may be the same.
I've swapped solenoids and the intermittent problem persists.  I can usually make it work by jiggling the key in the crank position.  I had recently removed the lock cylinder and thought maybe I,d lost the spring.
I also removed the cylinder from another 67 and found no spring there - maybe this is just a 65/66 thing.
I guess next step is to try a new ign switch unless anyone has a better idea.   Hate to change out the orig. date coded switch.
Kurt.
« Last Edit: July 02, 2016, 10:56:33 AM by 67350#1242 »
67 GT350 SJ 2/01/67
« Reply #3 on: July 02, 2016, 12:29:06 PM »
Kurt.
65/66 ignition switch is ALTOGETHER different. in 1968, the switch changed again too! (68's dropped the accessory post from the back side, key cylinder stayed the same)
65-67  Ford products with a REVERSIBLE KEY, use an ignition switch that was updated in 68 because of problems with excessive electrical current loads of high-optioned cars.  If the key is NOT a Reversible one within the 65-67 model years, the switch and everything about the switch is entirely different too.
