Author Topic: 1967 front drive shaft slip yoke needed  (Read 721 times)
Offline mtinkham
  • That'll be easy
« on: July 01, 2016, 01:38:56 PM »
Application is a July 67, 289 2v C4.  I am not concerned with date codes...looking to replace a worn slip yoke.
The yoke is worn in one spot.  The spot is approximately 1" wide and runs the length of the tail-shaft bushing.  Would this have been caused by a bad U-joint (tight or loose) some time in the past, a balance issue, or possibly something else I should be concerned with?  Current front u-joint does not bind and does not seem loose.  Not sure if it is original...my guess is no.
I intend to replace the seal and bushing.
