Author Topic: 66 Driveshaft Markings - C Code Automatic  (Read 4245 times)
Offline rrenz
« on: June 30, 2016, 10:17:29 PM »
Curious if anyone has any insight on the factory markings.Replacing the u joints on my 66 C Code NJ coupe and would like to replicate the factory markings. It appears as though there are 5 stripes on my driveshaft. The two in the center appear to be the aqua color and pinkish color. However the three colors at the rear are completely gone.
« Last Edit: May 21, 2020, 09:14:08 PM by J_Speegle »
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Re: 66 Driveshaft Markings
« Reply #1 on: July 01, 2016, 01:03:36 AM »
What transmission and when was the car built?
Offline rrenz
« Reply #2 on: July 01, 2016, 07:50:07 AM »
C-4 . Build date is Jan 21st
Ryan
C-4 Automatic
Build Date Jan 21st
« Reply #3 on: July 05, 2016, 06:55:32 PM »
I suppose that you read this thread. Might provide you with a possible answer to the rear two stripes. There is reference and markings from a very close similar car/example
Often there were identification markings and then additional markings added form other reasons
http://www.concoursmustang.com/forum/index.php?topic=13723.msg85034#msg85034
Offline Josep
« Reply #4 on: July 06, 2016, 04:41:11 PM »
It's a bit dark here and not much space to look under the car but, I can slightly see what it looks like 3 yellow stripes close the rear axle. When I have the time, I will jack-up a lil the car and see if I can find more info.
Btw, is there a way to clean the driveshaft without removing the yellow marks/numbers.? Just clear water with maybe some soap will work.? Thanks.
Josep
Offline Building 3
« Reply #5 on: July 06, 2016, 05:43:25 PM »
I used Evaporust. It took off the rust without harming the paint.
Offline Josep
« Reply #6 on: July 06, 2016, 06:56:22 PM »
I have no availability to evaporust here in Ibiza Isl. Look for something similar..
Josep
« Reply #7 on: July 06, 2016, 07:20:11 PM »
Might check to see if something like Naval Jelly is available and test it in just a small section of the painted area and time the application to a short period then repeat if needed.
Light colors often look like other colors due to exposure, the elements and age. Once down to the paint you will need to lightly sand, steel wool or other wise remove the top oxidized surface to get a better look at the true color
White, pink, tan, and yellow can all look like one another if you skip this step.
Last option would be to use lye on a section of each stripe (it will remove it completely leaving nothing) it will bubble and expand in the bubbles but will let you see the color as it removes. By doing only one smaller section of the larger stripe you will get a chance to try other options. Oven cleaner (over here) is a handy way to purchase it. Spary it carefully in a container (like a glass jar) and apply it with a brush. Watch and take care with eye, hand and skin protection from splatters and spray
Offline Josep
« Reply #8 on: July 07, 2016, 02:42:47 AM »
Thanks Jeff, will try those options to see if I can recover the true color of stripes.
Josep
Offline WT8095
  • Dave Z.
« Reply #9 on: July 08, 2016, 02:10:59 PM »
Sodium hydroxide (lye) is also the principal ingredient in drain cleaner. Nasty stuff, but very effective. Can also be used as a rust remover, and will not erode the base iron or steel. I will add emphasis to Jeff's comments about safety. Make sure you use protective equipment.
Dave Z.
Offline rrenz
« Reply #10 on: July 08, 2016, 09:34:02 PM »
Well after allot of research and very small specs of paint under a magnifying glass i found and determined that both ends of the driveshaft saddles were painted with some sort of red paint or primer and the yoke had evidence of yellow paint on the bearing caps. I found one salmon stripe and a fatter aqua stripe in the center.very sloppily applied. There were three more stripes at the axle end of the driveshaft however I have no evidence of what colors they were. this is ultimately what i ended up with after a few afternoons. I can't say for sure if this is the original driveshaft. PO switched out blocks at some point so i have no way of knowing if the shaft or yoke is original to the car however i would assume that it is.
Ryan
C-4 Automatic
Build Date Jan 21st
« Reply #11 on: July 08, 2016, 09:41:08 PM »
Well after allot of research and very small specs of paint under a magnifying glass..............There were three more stripes at the axle end of the driveshaft however I have no evidence of what colors they were. this is ultimately what i ended up with after a few afternoons. ........................
Just for the record - what transmission did your car originally have and when was it estimated to be built?
Offline rrenz
« Reply #12 on: July 09, 2016, 08:33:11 AM »
according to the build sheet c-4 auto with a January 23 1966 build date
Ryan
C-4 Automatic
Build Date Jan 21st
« Reply #13 on: July 09, 2016, 05:55:29 PM »
Offline Josep
« Reply #14 on: July 12, 2016, 04:45:51 PM »
Here's my marks, well, more or less because apart from the marks, if there's numbers there (guess there are!) i can't read them.
One mark looks greenish and the other white. I can't see any other.
Close to these marks, there's something that looks like numbers, but unreadable for me unfortunately.
Josep
