Author Topic: Jack Decals -  (Read 2575 times)
Jack Decals -
« on: June 28, 2016, 04:01:02 PM »
The attached picture of a jack has the original "Jacking Instruction" decal. I removed the jack from the car of the proverbial little old lady that drove her 66 Mustang I-6 AT for years, and then the car was wrecked by her grandson. I assume it is the original, there was no reason to replace it. All I remember about the car is - 66, January (or later) build, San Jose, Hardtop, faded red, black interior (torn seats).
Shown are four reproduction decals, none of which are accurate.
Dimensions, details and comments:
Original - 3/4 X 1 15/16; 3/32 corner R; 0.132 Type height, bold.
Top - 1 X 2; 1/8 corner R; 0.108 Type height, bold.
2nd - 15/16 X 1 15/16; 3/16 corner R; 0.112 Type height, bold.
3rd - 3/4 X 2; 1/8 corner R; 0.110 Type height, narrow.
Bottom - 7/16 X 2; no corner R; 0.105 Type height, narrow.
The reproductions decals came from different "Decal Kits" over many years. The bottom line is to be careful when you order decals.
« Last Edit: March 10, 2023, 04:08:59 PM by J_Speegle »
Re: Jacking Decals -
« Reply #1 on: June 28, 2016, 04:49:52 PM »
Not related to the decal but from the side profile it is hard to tell if is a typical SJ jack. That is more a detail seen from looking down from above as the jack is sitting on it's pad. +1 on must be careful buying repro tags.
« Reply #2 on: June 28, 2016, 07:36:31 PM »
You may have hit on it without knowing. According to Marcus Anghel's jack write-up, it's a 65 jack, no plant differences. The welded on nut is the giveaway. I'm going to call some little old lady's grandson about this.
« Reply #3 on: June 28, 2016, 08:19:31 PM »
Marcus 's well done article can have some additional info added. It is a community effort with the info after all. Marcus did all the heavy lifting putting it together. Two types used in 65/66. One has a solid steel block that the drive is threaded through and the other style has the drive threading through a nut welded on a "U" shaped bracket. Throw in fine and course thread and you have a few variations .
« Reply #4 on: June 28, 2016, 09:15:34 PM »
You are getting close, it's actually a double thread, 7/16-14(7) double, and the crests look almost square cut, or worn. The crests are flat, but possible tilted toward the drive end.
« Reply #5 on: June 28, 2016, 11:10:08 PM »
...and no date stamps.  Pretty unusual for FORD.  Brian
« Reply #6 on: June 28, 2016, 11:41:14 PM »
It is safe to say most do not have date stamps.
Offline WT8095
  • Dave Z.
« Reply #7 on: June 29, 2016, 01:20:51 PM »
I expect the threads are either acme or buttress profile.
Dave Z.
