Author Topic: Horns: Paint Daub  (Read 3783 times)
Offline Building 3
Horns: Paint Daub
« on: June 27, 2016, 11:04:51 AM »
This yellow paint on the Mustang horn does not look to me like it was put on at the plant or the supplier. Has anyone seen this before ?  It looks more like s previous owner was using the horn for a test spray of the color for some other project. Any thoughts? Thanks.
Re: Horns: Paint Daub
« Reply #1 on: June 27, 2016, 04:38:48 PM »
Have not seen that spray on any others nor have seen/heard of that finding by any other owner that I can recall. Would suggest that it not be reproduced at this point (document as you have) until you find other confirming original examples from same plant and time. Easy to add later if you can find support
Offline Building 3
« Reply #2 on: June 27, 2016, 05:43:47 PM »
Thank you. That is what I thought.
Offline JKWilson
« Reply #3 on: June 27, 2016, 09:12:20 PM »
If the horn in question is for your Dearborn convertible, I figured I'd offer this up if would be any use to you. This came off of my June '66 Dearborn coupe and it was the only marking I found on either of my horns:
Offline Building 3
« Reply #4 on: June 28, 2016, 11:35:43 AM »
Thanks.  Now I know what to look for in an original horn, a date code, no paint daubs.
Offline Hipo giddyup
« Reply #5 on: June 28, 2016, 01:21:48 PM »
I've seen these before as well. Wonder if anyone has remade a stamp like this for the show circuit?? Shouldn't be as hard as the "paint OK" stamp as less detail?
« Reply #6 on: June 28, 2016, 04:25:34 PM »
There are different date formats and placement.  It's not the same for all.
« Reply #7 on: June 28, 2016, 06:08:25 PM »
Yes I've made some to fill the need at the time
As far as the paint inspector stamp - depends on which one and year ;) For me every detail has to be drawn so its about the number of features and details. IMHO can't just type out the details using a specific font and call it good/close  ::)
« Reply #8 on: June 28, 2016, 07:11:29 PM »
Agree with you there Jeff. My next project is my July built Dearborn coupe. I'm sure the horns were touched up over the last few decades so I'll have to investigate if the stamping/format from the June 66 Dearborn example would be close.
Offline ChrisV289
« Reply #9 on: June 28, 2016, 10:39:02 PM »
This was off a friend'ss 66 San Jose coupe that's been in the family since 69. It is a January built car.
2009 V6 Mustang Coupe
Offline NEFaurora
« Reply #10 on: June 29, 2016, 01:31:36 AM »
Yeah, Those are typical '65-'66 Horn Ink Stamped Date codes.  It would be nice if someone would make up a "Stamp Set" with those letter/number fonts.  I'm more than sure Speegle has already done it (had those fonts stamps made)...I don't ever remember seeing a paint Daub on the bottom though on any ones I've ever seen.. That is a new one..  :o))
:o)
Tony K.
MCA#70001
Offline 2+2=GT350
« Reply #11 on: June 06, 2017, 12:16:17 AM »
I realize this post is a year old, but wanted to keep all the info together. Getting ready to restore my horns and noticed I have one as pictured by the OP (yellow paint daub). My horns are original to my car which is a March Dearborn built fastback. The paint daub is only in the LOW pitch horn. Maybe this was to distinguish between the HI and the ye(LOW) horns? My cars DSO if that matters is Indianapolis. Thanks, Bill
Offline Building 3
« Reply #12 on: June 06, 2017, 10:28:34 AM »
It looks like the same shade of yellow. Both sprayed at a close distance. Well, that's two examples.
« Reply #13 on: June 06, 2017, 12:56:15 PM »
I realize this post is a year old, but wanted to keep all the info together. Getting ready to restore my horns and noticed I have one as pictured by the OP (yellow paint daub). My horns are original to my car which is a March Dearborn built fastback. .............
Thanks - to paint :)  a more complete picture March of 65 or 66?
Offline 2+2=GT350
« Reply #14 on: June 06, 2017, 10:21:00 PM »
Sorry it is a 65. Build date March 11
