Author Topic: WTB 1967-8 Solenoid to dash Convenience feed wire.  (Read 1516 times)
1967 eight barrel
  • Guest
« on: June 26, 2016, 06:30:24 AM »
Looking for the feed wire for a 1967 or 8 Mustang or Cougar convenience group feed from the solenoid to the dash.
Re: WTB 1967-8 Solenoid to dash Convenience feed wire.
« Reply #1 on: June 26, 2016, 08:08:53 AM »
Two different versions I know of were used for this wire. My understanding is it is an early/late '67 thing (all 68 same) but have yet to determine a cut-off date. Early version runs alongside the headlight harness, over the brake booster along the pinch weld of the cowl and to the connection near the right hand shock tower. The late version was shortened to run along (clipped to) the right hand shock tower support (to the same connection point).
Being you are working on a Shelby, I would consult one of the Shelby Guru's and see what they can offer.
« Last Edit: June 26, 2016, 08:11:23 AM by 67gtasanjose »
1967 eight barrel
  • Guest
« Reply #2 on: June 26, 2016, 04:02:28 PM »
Rich, do you have either?
                             -Keith
« Reply #3 on: June 26, 2016, 04:39:55 PM »
                             -Keith
I have only the long one, I can get you measurements and photos but it is intended for use on my car.
« Reply #4 on: June 26, 2016, 04:56:22 PM »
I bumped an older thread to bring up images and measurements of the longer version (early) of this wire you are looking for. I understand the shorter version is very similar but I don't recall anyone discussing the length of that version within the thread.
