Author Topic: Staples  (Read 3953 times)
Staples
« on: June 22, 2010, 04:04:42 PM »
Anyone ever looked into what type of stapler would be necessary to install splash shield rubber and the rear interior quarter fuzzy strips?  (65-66 fan shroud rubber pad too!)
Found a couple places that sell them.  Guess I need to figure out the metal thickness first.
Offline Skyway65
  • Gold Level Subscriber
Re: Staples
« Reply #1 on: June 22, 2010, 04:50:35 PM »
Charles- My dad retired from Chrysler many years ago.  They used similar staples on the line where he was.  He mentioned that they had a huge Bostitch stapler that would do those staples with no trouble.  Not much in the way of details but I'm sure the thing must be pretty big!
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline SCJSTU
Re: Staples
« Reply #2 on: June 22, 2010, 09:33:04 PM »
speaking of staples....my 70 Mach 1 has holes on the radiator support for the hood seal.....
did the staple gun actually shoot the staples through the metal support?.......pretty strong gun/staples?
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
Re: Staples
« Reply #3 on: June 22, 2010, 10:02:55 PM »
Yes they did - must have made some noise!!
Offline Sunlitgold68
Re: Staples
« Reply #4 on: June 23, 2010, 02:46:38 PM »
I would say a high powered Pneumatic stapler like this.....
http://www.amazon.com/Stanley-Bostitch-P50-10B-Pneumatic-Stapler/dp/B000LB6K7A
8T01C204XXX
Built May 14th, 1968
Re: Staples
« Reply #5 on: June 23, 2010, 03:00:46 PM »
That might work.  Would have to find out what kind of thickness it's capable of plowing through.
Re: Staples
« Reply #6 on: June 23, 2010, 03:14:10 PM »
it doesn't look 'bad' enough to me. better be careful with the rebound/richochet though.........
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: Staples
« Reply #7 on: June 23, 2010, 03:45:57 PM »
I took the cheap but laborious way out when I did my splash shields 20 years ago on my Rangoon Red one.  I drilled (2) 1/32 holes through the steel and the rubber at each staple location.  Then I used 0.030" dia. stainless safety wire to make a staple for each spot.  I put them in by hand, and pecked on them while holding a dolly behind to tighten up the bends.
66 Metuch Conv
Nightmist, Std Blu Int
Offline NEFaurora
Re: Staples
« Reply #8 on: July 01, 2010, 10:44:05 PM »
I use the same method.. In metal areas, I drill super tiny holes and press the staples through, and then bend them tight on the other side, On areas that already have holes stapled such as a radiator support, I take a different approach, I take out the old staples for re-use, put the new rubber over the existing holes, then go on the backside and re-create the original holes areas by marking it in the rubber on the backside of the rubber where the original holes are accessable, then I just re-create the holes in the rubber in the correct areas, and push through the original staples and re-bend...or use new staples and bend them...works like a charm...and you utilize the original staple holes to boot.
Tony K.
MCA#70001
