Author Topic: 70 convertible inner rockers question  (Read 1208 times)
Offline opcfan
« on: June 16, 2016, 10:59:46 PM »
Years ago I purchased inner rockers for my 70 Mustang convertible. I am just now getting around to installing them and have a couple of questions:
1.
The rocker are to long and will need to be cut back is this normal?
2.
I know I ordered the convertible rockers but how can I know if this is what I got. I am assuming the coupe and  fastback use a thinner gauge steel in the manufacturing process. What gauge thickness should they be?
Thanks Jim
Offline cobrajetchris
Re: 70 convertible inner rockers question
« Reply #1 on: June 16, 2016, 11:41:26 PM »
This is a major project to do and if you have never done this kind of heavy structural work I would not recommend it. The car will need to be supported properly while the inner and outer rocker are cut out or the body will sag and nothing will fit. As far as your question about the reproduction rockers, I would assume the parts will need to be modified as with most reproduction parts. The reproduction parts have gotten better over the years so if yours are really old I would recommend buying a new set and see for comparison. Good luck to you.
CHRIS KNOBBE
Offline WT8095
  • Dave Z.
« Reply #2 on: June 17, 2016, 12:10:47 AM »
Quote
Assuming you're talking about just inner rockers, the easiest way to tell if they're for a convertible is that they're inner rockers. They were only used on convertibles.
+1 on Chris' comment that this is a very advanced project, even for an experienced welder.
Dave Z.
Offline opcfan
« Reply #3 on: June 17, 2016, 01:12:55 AM »
Thanks for the advice but I am to far into the project to back out now. I have a very experienced welder lined up to weld it but I want to do all the prep work myself including tacking everything into place. I am just waiting for the rear aprons to arrive.
Offline WT8095
  • Dave Z.
« Reply #4 on: June 17, 2016, 02:11:31 PM »
Have you started cutting old metal out yet? How do you have the car braced?
Dave Z.
