Author Topic: C4 Oil Pan  (Read 2763 times)
Offline sparky65
C4 Oil Pan
« on: June 21, 2010, 10:55:59 PM »
So I just got the trans back from the rebuild shop.  Unfortunitly it didnt come nearly as clean as i hoped.  I later learned i should have aske what type of cleaning solution they were going to use.  They aparently put it in a big dishwasher machine with a degreasing solution so there was no caustic cleaners involed.  The upshot of all this is that the the paint that was there is still there.  Some how i thought the oil pan should be bare steel but i found quite a few traces of black paint.  Any idea if this could be correct?
Now i have to go study the case cleaning post and figure out which cleaners i want to try.   :(  I was really hoping it would be cleaner.
Steve
2009 Black GT Coupe
Re: C4 Oil Pan
« Reply #1 on: June 22, 2010, 12:05:58 AM »
The pans were typically natural, but not something I have spent a considerable amount of time studying!
Offline gtamustang
  • CPM
Re: C4 Oil Pan
« Reply #2 on: June 22, 2010, 04:20:40 PM »
Working as a transmission specialist in the late 70s-early 80s, I never found painted parts on any of the Ford C-3, C4, FMX, or C-6 transmissions. (1,000s of Fords from the late 50s to near new 79s).
You pan was bare stamped steel from the factory. Anything else was added through a previous owner!
Regards,
Pete Morgan
Offline macdude67
Re: C4 Oil Pan
« Reply #3 on: June 22, 2010, 09:07:27 PM »
and any type of caustic soda should not be used on aluminum parts. sodium hydroxide is highly reactive with aluminum and will corrode aluminum almost instantly. this represents a problem to any part of the case that has a smooth bore where a seal rides such as the servos.
Offline sparky65
Re: C4 Oil Pan
« Reply #4 on: June 22, 2010, 10:18:40 PM »
Regards,
Pete Morgan
Thanks, that's kind of what i thought.  Now the question is was the pan replaced or was it just painted.  Is there any identifying marks i should be looking for to confirm it is original?
Steve
2009 Black GT Coupe
Offline Sunlitgold68
Re: C4 Oil Pan
« Reply #5 on: July 01, 2010, 05:00:59 PM »
"Working as a transmission specialist in the late 70s-early 80s, I never found painted parts on any of the Ford C-3, C4, FMX, or C-6 transmissions. (1,000s of Fords from the late 50s to near new 79s)"
Looking forward to a perfectly rebuilt and flawless transmission!  :)
8T01C204XXX
Built May 14th, 1968
Offline NEFaurora
Re: C4 Oil Pan
« Reply #6 on: July 16, 2010, 01:12:23 AM »
Not to get off topic, but I've had issues getting the right '65-'66 C4 tranny pan gaskets.   Everytime I order one from no matter wherever, They send me the later '67 and later C4 tranny pan gaskets.  Does anyone know where I can can get the correct gaskets?  Even NPD sends me the wrong ones.  The correct gasket should be completely square, Not Square with a "bump" in the side.. which is what I keep getting sent to me.
Anyone have a source for the right gaskets?
If someone could post pics of the early C4 gasket and the later C4 gasket, I would appreciate it.  I don't have any pics handy, I'd have to dig for them.
Tony K.
MCA#70001
