Author Topic: 68 manual shifter boot upper with a center console ?  (Read 1070 times)
Offline mhubert89
« on: June 15, 2016, 05:37:13 PM »
Hi !
How the upper boot was fix with a center console ? Its is the same boot with and without a center console ?
Its the boot c5zz-7277-B from CJ will fit with my center console ?
Mustang Fastback 1968
289, 4 speed
Re: 68 manual shifter boot upper with a center console ?
« Reply #1 on: June 20, 2016, 05:10:39 PM »
Believe the top and bottom boots are the same with and without the console. (based on same engine and trans application)
2/68 MPC lists C5ZZ-7277-B as the service part at that time so should be a fit
Offline mhubert89
« Reply #2 on: June 20, 2016, 08:26:57 PM »
Perfect ! Thks
289, 4 speed
Offline 68NordicCat
« Reply #3 on: October 04, 2016, 03:10:03 PM »
Have a follow up question....with a console how is the carpet installed around the upper boot? Is it screwed to the floor under the upper boot (between the lower and upper boot flanges) or are the boots mounted and then the carpet just cut around the base of the upper boot (trans tunnel metal, then lower boot flange, then upper boot flange, then screws then carpet)? If the latter is the carpet secured to the floor somehow other than just the console holding it down?
Have a 12/67 SJ built '68 Cougar - J code 4 spd
12/67 SJ Built 68 J code 4-spd Cougar
