Author Topic: 68 rear vent hose location ??  (Read 2954 times)
Offline mhubert89
« on: June 15, 2016, 05:34:37 PM »
Hi ,
Did someone have a picture of the exact location to bolt and put the rubber vent hose of the rear axle housing to under de body ? Just want to make sure to put this bolt at the good place !?
Mustang Fastback 1968
289, 4 speed
Re: 68 rear vent hose location ??
« Reply #1 on: June 15, 2016, 06:41:19 PM »
Hi ,
Should be a bolt hole unless sheet metal has been changed . It is shown in the assembly manual although not clearly.
Offline mhubert89
« Reply #2 on: June 15, 2016, 07:01:35 PM »
Yes new sheet metal.. That why i ask a picture , less easy to do a hole at the good place.. Shop manual its hard to see !
289, 4 speed
Offline Hipo giddyup
« Reply #3 on: June 16, 2016, 10:11:57 AM »
 I'll try to get a pic of my 67', though not a 68'. Maybe someone here can post their 68' pics , but i don't think there should be much difference.. The attached pic is the "general idea".
Offline mhubert89
« Reply #4 on: June 16, 2016, 01:07:54 PM »
Perfect ! Thanks
289, 4 speed
« Reply #5 on: June 18, 2016, 02:54:55 PM »
Finally got a chance to get a picture under my 67'. Although it might not be exact for a 1968, I hope you get the idea. And yes, I will soon be swapping out the kyb shocks with more original ones.  ;D
« Reply #6 on: June 18, 2016, 04:09:01 PM »
Some measurements would help as well.
1967 eight barrel
  • Guest
« Reply #7 on: June 19, 2016, 01:56:28 AM »
I'd be glad to measure my 1967 GT 500 if that would help you.
        -Keith
« Reply #8 on: June 20, 2016, 05:00:32 PM »
There is at least one picture in earlier 68 Unrestored car threads
Try - Jan 68 San Jose Fastback Non-Foldown
Offline mhubert89
« Reply #9 on: June 29, 2016, 12:59:35 PM »
Job done ! Thanks for picture that help me a lot ! Car coming together !
289, 4 speed
« Reply #10 on: June 29, 2016, 02:12:01 PM »
Your hose clamp is backwards the hose should be to the out side of the bolt.
Offline mhubert89
« Reply #11 on: June 29, 2016, 02:36:10 PM »
The hose suppose to past under the bolt ? Or you mean i just need to turn for 180 degre the clamp ?
289, 4 speed
« Reply #12 on: June 29, 2016, 04:04:54 PM »
From that thread I listed above - notice the difference in the orientation of the bolt and clamp to the shock support section of the floor
Not that its a big thing (just an observation) but also notice the the clamp at the rearend was clamped from the right (in the picture) might be due to access and a right handed worker (not sure if Ford hired left handers) or to make it easier since the brake lines are to the left of the vent nipple
« Last Edit: June 29, 2016, 04:08:53 PM by J_Speegle »
