Author Topic: 67 speedo cable  (Read 1551 times)
Offline bazza
67 speedo cable
« on: June 12, 2016, 09:52:54 PM »
Is there a difference between a 390 c6 cable, and a small block c4 cable?
Length of the c6 cable?
67 Dearborn S code coupe Built 8/17/67
Re: 67 speedo cable
« Reply #1 on: June 12, 2016, 10:06:40 PM »
Yes there is a difference. The C-6, C-4 and the 3spd all enter the transmission on the LH side. The 4spd enter on the RH side making it longer,regardless whether it is a big block or a small block.
Offline bazza
Re: 67 speedo cable
« Reply #2 on: June 15, 2016, 02:14:35 AM »
Thanks Ruppstang, so only two cables, 4spd and then everything else.
Re: 67 speedo cable
« Reply #3 on: June 15, 2016, 07:58:16 AM »
I believe (without verified research) that all three applications that enter the transmission on the driver side (left side) are the same replacement part number and the 4-speed version (enters on the right side (passengers side) of the trans is the only different one.
C-6 applications are slightly more to the rear (slightly different hardware/length) so I would not be surprised that for "Factory Use", Ford had a different engineering number than the C4 or 3-speedo's, but about 100% sure the Service Part would be the same.
« Last Edit: June 15, 2016, 10:34:48 AM by 67gtasanjose »
Re: 67 speedo cable
« Reply #4 on: June 15, 2016, 10:01:52 AM »
The 67 MPC lists seven different casing and core assemblies.
Re: 67 speedo cable
« Reply #5 on: June 15, 2016, 10:37:02 AM »
Yes, kinda what I was saying.
Fairly sure later MPC's show the non-Speed Control cars with only two available (again, without verifying) one for a four speed and another for all others.
Re: 67 speedo cable
« Reply #6 on: June 20, 2016, 05:19:38 PM »
Can report that 1968 MPC lists 9 different choices for 67 Mustang speedo cables so
Maybe by almost 10 years later only a few versions were left - would make sense and match our understanding that Ford tried to redesign and reduce the number of parts to reduce inventory needs and costs. One of the reasons "NOS" is not equal all the times to original parts and details
Just for the record the 68 version list 5 versions for 68 Mustangs
