Author Topic: 68 Wire Harness ID Tags, Where and how are they attached?  (Read 841 times)
« on: June 12, 2016, 07:27:20 PM »
As an offshoot of the 67 Wire Harness ID & Inspection/Assembler's Tag thread I post the following to help others as they progress through their 68 Concours projects. Remember to check the application as it can make a difference in label and location. Often both the identification (often have a colored section to help speed identification)  and assemblers (most often completely white background) location can still be seen on these original looms
Hope these help
ENGINE COMPARTMENT
8T01T2050xx Hood turn ind loom label. Ignore the AMC/American Motors style master cylinder  ::)
8R02J1247xx Drivers side firewall
8R01C1267xx Drivers side firewall
8F01T2053xx Drivers side firewall
8R02J1247xx Alternator loom
8R01Txx engine feed loom
8F01T182xxx engine loom label
8F01T2053xx engine ground
Re: 68 Wire Harness ID Tags, Where and how are they attached?
« Reply #1 on: June 12, 2016, 07:31:35 PM »
68 Wire Harness ID tags cont.
INTERIOR
8R02S1606xx steering column loom
8R01J1035xx Dash loom
8R01C1496xx Dash Loom
8R01C1426xx under dash loom label
8F01T182xxx under dash loom label
« Reply #2 on: June 12, 2016, 07:33:49 PM »
TRUNK AREA
8F01T182xxx Fuel sender loom label
8R01J1614xx Fuel sender loom
8R01C1673xx fuel sender loom fuel sender loom
