Author Topic: 66 Taillight Harness Routing  (Read 1119 times)
Offline rrenz
« on: June 12, 2016, 06:19:53 PM »
Having a little trouble finding the answer for this one. Hoping someone can shine some light on the subject. Installed a new taillight harness. P/O had spliced and diced the original so none of the clips or routing was correct. I see there is a nut clip and then a wheelhouse clip. Ive also seen a piece of tape holding the fuel sender to the wheelhouse. Which is correct and should used and where should they be attached?
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Re: 66 Taillight Harness Routing
« Reply #1 on: June 12, 2016, 09:21:31 PM »
Not much but don't see the gaffers tape or retaining clip used in any of these pictures
Wire seems to be of different thickness's for some reason - might just be me :)
6T08T1488xx Fuel sender wire
6T07T1522xx Fuel sender wire
6T07T2705xx Fuel sender wire
6T07C2787xx Fuel sender wire
Not the best pictures for your use - just what I have
Offline rrenz
« Reply #2 on: June 13, 2016, 06:15:00 PM »
not a problem. any help is appreciated  :)
Ryan
C-4 Automatic
Build Date Jan 21st
