Author Topic: 68 front brake line installation ??  (Read 3063 times)
Offline mhubert89
« on: June 09, 2016, 04:15:21 PM »
Hi !
I am installing my brake line on my 68. I bought a new set from scott drake stainless lines. Can someone told me if i put the 2 bolt for the front brake line in the good hole ? And which hole the rear brake line go ?
The other things, the front brake line who come from the passager side look to go to far again the shock tower .. Did i need to bend this line to go in the distribution block ?
Just let me know if the line are put correct , like one go over wich one ?
On the last photo , where go all this little lines ?
Mustang Fastback 1968
289, 4 speed
Re: 68 front brake line installation ??
« Reply #1 on: June 09, 2016, 05:03:40 PM »
We've got Dearborn 68 Small block 4 speed April 68 built from your signature - could you help by providing Drum brakes, Power Drum or Power Disc so that we can make sure we get the best match ;)
Offline mhubert89
« Reply #2 on: June 09, 2016, 05:12:46 PM »
Yeah sorry !!
Front power disc brake with rear drums brake !
289, 4 speed
« Reply #3 on: June 10, 2016, 07:20:34 PM »
Was difficult to find any pictures in my files where the master cylinder and booster were out (as well as the engine) and the lines were still in place. Might want to compare the assembly manual drawings to the bits and pieces below
Ignore the PO changes  ::)
Offline Chris Thauberger
« Reply #4 on: June 10, 2016, 08:05:13 PM »
This should be what you are looking for.
Offline mhubert89
« Reply #5 on: June 11, 2016, 12:43:42 AM »
Exactly !perfect picture !  Thanks
289, 4 speed
Offline mhubert89
« Reply #6 on: June 11, 2016, 12:45:44 AM »
And thanks jeff ! Picture help a lot ! Understand that is hard to have a good picture with everything in place !
Appreciate your help ! Hope you saw that i follow all your post reply , you can see that i buy the hot rod black like you mentionne me for my engine bay ! Always good answer
Math
289, 4 speed
Offline TLea
« Reply #7 on: June 11, 2016, 08:44:15 AM »
From your 4th picture you are missing a line. Top and bottom go from distribution block(top) to master. Middle two go between distribution block and prop valve. Should be another that goes from front port of distribution block to LF brake hose
Offline mhubert89
« Reply #8 on: June 12, 2016, 12:16:31 PM »
perfect thanks ! no i have its , just install the LF yesterday !
289, 4 speed
Offline mhubert89
« Reply #9 on: June 12, 2016, 12:18:02 PM »
my concern its the picture 3, look like my firewall line front the passager side lines, go too far in the shock tower.... look like the bend its not right ?
289, 4 speed
