Author Topic: 67 Rear End & Brake Parts - original color/finishes for these parts ??  (Read 1442 times)
Offline mhubert89
NOTE: Split from another thread related to front suspension details
Quote from: mhubert89
What is the finish for the black on the rear end housing SGB ? The rear hubs are cast iron ? And for the retainer plate ?
Pictures of each/most are shown in other threads as well as articles and threads showing or offering tips as to how to reproduce the original look
« Last Edit: June 06, 2016, 06:55:01 PM by J_Speegle »
Mustang Fastback 1968
289, 4 speed
Hey Jeff, what is the finish for the black on the rear end housing SGB ? The rear hubs are cast iron ? And for the retainer plate ?
Sorry for the delay - its show month so many of us will be traveling this month and away from the internet
Rear housing is a SGB with a natural unpainted surface were the third member attaches
Rear brake drums are cast steel  - normally darker IMHO that what one would see with just bare cast iron - cast black paint as a result of heat treating of some form
With machined surfaces surfaces highlighted and weights natural untreated steel
Pictures are not offer to illustrate anything other than contrast between the different metals and surface details possible on your particular style of brake drum
Not sure what your referring to as a "retainer" plate. Could you help out here so I can help you out. :)
« Last Edit: June 06, 2016, 06:53:05 PM by J_Speegle »
Offline mhubert89
Thanks again Jeff, i talk about the bearing retainer plate in the picture here !
« Last Edit: June 06, 2016, 06:53:16 PM by J_Speegle »
289, 4 speed
Offline mhubert89
Here Jeff, took a picture today to help what i mean ! The hubs and the plate , need the original color ! Thanks
« Last Edit: June 06, 2016, 06:53:24 PM by J_Speegle »
289, 4 speed
Came up with bare steel
Going to split off these last few exchanges since they deal with rear suspension ;)
« Last Edit: June 06, 2016, 06:53:31 PM by J_Speegle »
Offline mhubert89
Thanks for your research ! Appreciate
289, 4 speed
