Author Topic: Wire/Starter Cable Routing From Solenoid - 65 San Jose C code  (Read 1676 times)
Offline tvor
Hi guys,
can you tell me if the battery cables are supposed to go into the wire straps?  If so, that bottom one is going to be a bugger!
« Last Edit: June 06, 2016, 06:31:11 PM by J_Speegle »
'65 Coupe, built in San Jose.
289 CID with C4 trans.
Door plate date of 9/11/64
Original owner - mom
Second owner - me!
Offline C6ZZGT
Re: Wire/Starter Cable Routing From Solenoid - 65 San Jose C code
« Reply #1 on: June 05, 2016, 01:21:06 AM »
i`d say no the battery cables do not go into those straps,just the smaller wires.
« Last Edit: June 06, 2016, 06:31:19 PM by J_Speegle »
Brian
66 GT Coupe 6R07A143871 owned since 1983
40+ yr parts man , over 25 with Ford.
« Reply #2 on: June 05, 2016, 08:51:04 PM »
Took a look at the pictures I have and could not find an example from that month - that factory that I could post as a good example IMHO
Here are a few examples from just after that period and a bit later (partical VINs included for comparison) Also included with the wire retainers in the general area to help others with similar questions now and in the future
5R09C1508xx
Does not show that retainer just out of the picture above. It may hold wires and cable but can't be sure
Late Oct 64 car. Original picture from 64-65. Cable in the upper clip/retainer (purple arrow) but not in lower
5R07C161xxx In upper not in lower
5R09C1800xx
Sorry no smoking gun from my stuff
Your question motivated me to post two other related threads related to the same start cable
« Last Edit: June 06, 2016, 06:31:28 PM by J_Speegle »
Offline tvor
« Reply #3 on: June 14, 2016, 12:50:25 PM »
Thank you Brian and Jeff.  I think I'll follow the later vehicles with the cable in the upper retainer only.  If I need to change, at least it isn't that big of a deal to correct it.
BTW, took my car to the Friends of Steve McQueen car show and took home the trophy for best early Mustang!   ;D
Second owner - me!
« Reply #4 on: June 14, 2016, 11:24:56 PM »
Congratulations
