Author Topic: 67 Disc Brake Caliper Assembly and Rebuilding  (Read 3412 times)
Offline BKnapp
« on: June 01, 2016, 03:10:55 PM »
I finally finished cleaning, plating, and phosphating my caliper parts and have a few questions about putting it all back together...correctly. The car had been previously "restored" and the brakes were a mess. With the help off Jim's amazing spreadsheet, Jeff's pictures, the MPC, and the Shop Manual, I still have some questions:
1) Caliper mounting safety bolt - do these use lock washers? Mine had them, but I don't see one in the MPC illust.
2) Caliper assembly bolt - mine had one and this does appear to be correct. Interestingly, a remfg caliper I just recieved does not have the lock washer.
3) Crossover (transfer between inboard and outboard) brake line - I believe there should be copper washers, but mine did not have them.
4) 7/16 inlet line - I believe this should have a copper washer, mine did not.
Any insight and help is certainly appreciated!
« Last Edit: June 01, 2016, 03:29:59 PM by BKnapp »
Offline 67350#1242
Re: Help assembling 67 brake caliper
« Reply #1 on: June 01, 2016, 09:40:00 PM »
Lock washers on both Caliper mounting safety bolts as well as the bolts holding the 2 halves together.
Crossover line has no washers - they are flared tube fittings with tube seats.
Inlet brake hose line has flat copper washer.
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
Offline BKnapp
« Reply #2 on: June 01, 2016, 10:47:58 PM »
Thanks! So pretty much as I thought it should be and still have no idea why they included (2) 3/8" copper washers with the rebuilt caliper I bought. My first attempt at doing "anything"'on a car. I have never media blasted, played, phosphates, etc...It's not perfect, but the learning process and experimenting is fun.
« Reply #3 on: June 01, 2016, 11:33:26 PM »
Bill, the front half of the caliper was ether plated silver or painted silver . I have seen it both ways . This was a practice started in late 65 production so that flash rust on the casting would not be seen through the spoke of a deluxe wheel.
Offline mtinkham
  • That'll be easy
« Reply #4 on: June 02, 2016, 01:30:59 PM »
Bill...looks really good.  Doing your own work can be rewarding...frustrating at times...but rewarding.
Bob,
Attached is a picture of the left front caliper from my 67 April Metuchen FB.  I was under the impression the "silver" was originally black-out paint (my car came with styled steels) - simply faded and washed-out.  However, after reading your post above, the silver was probably silver, not black as I had originally thought.  Would this be consistent with my cars plant/month?
Mark
Note: ignore the red paint on the dust cap...PO painted many things red (differential, 12" long rear shackles, radiator support).....I guess in the 70's red made it go faster!
« Last Edit: June 02, 2016, 01:33:51 PM by mtinkham »
Offline BKnapp
« Reply #5 on: June 02, 2016, 11:56:30 PM »
Thanks for the input, Bob. I will probably give it another try this weekend. When looking at Marks picture (and others on a different thread), it looks like the plating only covered the outside face, not the whole outboard caliper. Is that correct base on your observations?
Thanks!
« Reply #6 on: June 03, 2016, 03:09:19 PM »
Thanks!
It started out in 65 as only cars with deluxe wheels from Ford got the silver out half calipers. Steel wheel cars were all cast iron. I guess ford thought it more practical to make them all the silver outer half way. As I wrote previously the silver on the outer half of the caliper evolved to being done as a production standard sometime in later 65 production . It continued through 66 and 67 production. The caliper is made up of two halves. The front halve(facing to the outside ) was typically plated or painted completely all over but just the outer half. If painting with the no smudge aluminum paints (Aluma blast etc.) are a very close approximation to what ever the factory used. The practice of "blacking " out the front calipers was for later years and a subject for another thread.
« Last Edit: June 03, 2016, 04:40:51 PM by Bob Gaines »
« Reply #7 on: June 05, 2016, 08:26:46 PM »
Realize (as we always remind each other) that service replacement parts don't always reflect the finishes, design or style of the factory installed part since on of these examples is a NOS piece but it does appear in this case the NOS part does match the factory finish
So to illustrate what is being discussed here are a few pictures
Offline BKnapp
« Reply #8 on: June 05, 2016, 09:09:55 PM »
Well, this is as close as I think I can get it for now. I want to get things back together so I can drive it and see what else might need attention. This winter I will likely tear into it again and start with the master cylinder.
Thanks for all the info and pictures!
« Reply #9 on: April 21, 2020, 04:22:29 PM »
Knee deep in this right now. Question concerning finish of each item. My guess is after the dash. Please note that this is for late 67 (after Nov/Dec 66).
1. Caliper half bolt -- PO
2. Caliper half bolt lock washer -- Cad with knurled outside
3. Caliper bleeder -- gold dichromate
4. Pad hold down --  PO
5. Pad hold down bolt with captive star washer -- zinc or PO according to NPD
6. Crossover tube --  Terene (not stainless)
7. Crossover fittings on tube-- natural
Blue is revised
For extra credit, what color is the backing plate on the Shelby brake pad? Gold Dichromate?
Pad color? Light blond?
« Last Edit: May 09, 2020, 02:07:24 PM by Bossbill »
« Reply #10 on: May 09, 2020, 02:19:29 PM »
Updated my synopsis with Cad for caliper half bolt lock washer (per Jeffs last pic) and PO for pad anti-rattle/hold-down.
« Reply #11 on: September 03, 2020, 09:31:27 PM »
In keeping with the spirit of this thread which is leaning toward assy line finishes on all parts, is the Kelsey-Hayes dust boot the correct one?
Jeff's pic appears to show a black brake pad and a metallic  friction pad.
Might be for a standard DB setup. The Shelby pad, in which I'm interested, is still unknown in its color.
Offline wils1514
1967 mustang kelsey hayes caliper rebuilding
« Reply #12 on: December 05, 2020, 02:14:04 PM »
In the process of rebuilding the front 4 piston kelsey hayes calipers. I've tried searching but couldn't find what I was looking for.
I have a couple questions on the finishes of some of the fasteners and parts.
What is the correct finishes for the following:
-2 bolts that attach the 2 caliper halves together
-2 lock washers for the caliper halves bolts
-Pad retaining clips
-bolts for retaining clips
1967 mustang, metuchen, Dec 25/1966
1967 Mustang fastback- build date: dec 23 1966-Metuchen
Re: 1967 mustang kelsey hayes caliper rebuilding
« Reply #13 on: December 05, 2020, 03:17:19 PM »
There's a bunch of them.
Start here:
http://www.concoursmustang.com/forum/index.php?topic=13837.0
Do note that I address a lot of finishes on the post Dec. calipers.
Offline wils1514
« Reply #14 on: December 05, 2020, 03:58:35 PM »
Thank you for the link! I knew I’ve seen one before but couldn’t find it again.
