Author Topic: 68 rear axle housing identification ??  (Read 2388 times)
Offline mhubert89
« on: May 31, 2016, 10:20:41 PM »
hi,
i am restoring my 68 fatsback. i remove the rear differentiel. on the housing i have a vent plug and a bolt. only have seen a housing with a vent. its my housing its original for my 68 ? if so, the vent hose and the brake hose block are not bolt togehter ?
Mustang Fastback 1968
289, 4 speed
Re: 68 rear axle housing identification ??
« Reply #1 on: May 31, 2016, 11:01:14 PM »
Looking at your signature - your car is a 2 barrel 289 4 speed without the GT package?
We see rearend housings like your pictures in certain big block applications so being a small block is going to be a new twist ;)
Offline bastille_stango
« Reply #2 on: June 01, 2016, 05:17:59 AM »
Appears to be a 9' rear end (typical rear bumpy shape) only available in GT package
In 1968, GT option was only available for 4 barrels V8
8F02J 63B T5 6A 25C 89 G W
TW PB GT CL FDS PS "Caroline"
Offline brennancarey
« Reply #3 on: June 01, 2016, 09:06:24 AM »
would this axle housing be correct for a early 67 GT 390 ?
67 GTA 390 Fastback
Dark Moss Green
Dearborn
Build Date 12/28/66
« Reply #4 on: June 01, 2016, 10:45:55 AM »
67's had the plug in the back until the transition gradually took place sometime in MAY. The book shows end of May but you know how that goes.
« Reply #5 on: June 01, 2016, 03:44:32 PM »
+1 with what Bob wrote and in addition the dual holes on the drivers side tube would not be an original feature also
Offline sportyworty
« Reply #6 on: June 02, 2016, 10:57:21 AM »
ALL GT optioned cars in 1968 received the 9 inch rear. That housing is well within 1968 production or later up to 1970
The 4 speed 2 hole housings started with the introduction of the 428 CJ due to interference from the staggered shocks.
I have owned 68 GT 4 speed cars built before the CJ introduction and they did not have the separate outboard hole. The single hole early cars incorporated the vent with the junction block. I believe at this point having restored and dismantled a lot of rear ends and owning a lot of 68 cars that Ford standardized the machining call out for 4 speed 9 inch housings to incorporate the 2nd hole at that point going forward. If your car is a 4 speed and was built sometime in the Spring of 1968 or later in the calendar year it likely retains the original rear housing.
« Reply #7 on: June 02, 2016, 04:32:03 PM »
Thanks Kerry for sharing your observations/experience with these
Offline sportyworty
« Reply #8 on: June 03, 2016, 11:01:52 AM »
Happy to contribute where possible.  This forum is really turning into a go to source for accurate tech.
Offline mhubert89
« Reply #9 on: June 03, 2016, 11:45:45 PM »
Oki thanks everyone for the information. I only have a 289, 4 speeds , C code so this housing its not the good one for my cars... Just buy the one i need today ! Thanks
289, 4 speed
« Reply #10 on: June 05, 2016, 07:58:26 PM »
Try our best and it only happens with good help/members  8)
Try to stay in our narrow focus with just the facts and no agendas other that promoting as well as supporting reasonable discussion new/possible findings.
