Author Topic: Correct Indicator stalk?  (Read 1629 times)
Offline 66RavenGTCoupe
« on: May 30, 2016, 10:33:40 AM »
So this indicator stalk is on my wife's 1965 SJ Convertible Scheduled Oct 20, 1964. Is this a non Mustang part or is it possibly a carry over part from 1964?
Dan.
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Offline 196667Bob
Re: Correct Indicator stalk?
« Reply #1 on: May 30, 2016, 12:46:11 PM »
The lever should be the same as on your '66. And yes, it is a carryover. It is Service Part No. C3AZ-13305-B.
Bob
MCA 04909
« Reply #2 on: May 31, 2016, 01:08:46 AM »
Thanks 196667Bob,
So my ultimate question is could/did some of these make their way onto early Mustangs like my wifes?
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
Offline NEFaurora
« Reply #3 on: June 29, 2016, 12:29:02 AM »
That is NO Carryover Turn signal arm.  It is a Turn signal arm from a '67 to '73 Mustang....Not '63 or earlier.  The Turn Signal arm that you have pictured is #C7ZZ-13305-A which is a '67 to '73 Mustang turn signal arm.
See links below:
1967-73 Turn Signal Arms - C7ZZ-13305-A:
http://www.ebay.com/itm/1967-73-Mustang-67-70-Shelby-Original-Used-Turn-Signal-Lever-/231992922710?hash=item3603db1256:g:1pwAAOSwepJXcR55&vxp=mtr
http://www.ebay.com/itm/1967-1973-FORD-MUSTANG-TURN-SIGNAL-LEVER-C7ZZ-13305-A-/262313791089?hash=item3d131ece71:g:tfAAAOSwWTRW1OVU&vxp=mtr
1965-1966 Mustang Turn Signal Arms - C5ZZ-13305-A:
http://www.ebay.com/itm/1965-1966-Mustang-Bronco-Fairlane-Falcon-Galaxie-Turn-Signal-Lever-Best-New-/262499411663?fits=Year%3A1965%7CModel%3AMustang&hash=item3d1e2f26cf:g:Yq8AAOSwyQtVlovm&vxp=mtr
http://www.ebay.com/itm/1965-Mustang-Turn-Signal-Lever-1966-Scott-Drake-NEW-/231906490641?hash=item35feb43911:g:DY4AAOSwSzdXBwVk&vxp=mtr
Part#C5ZZ-13305-A was the same part as the earlier Part#C3AZ-13305, The only difference was that #C3AZ-13305 has a painted Black stalk, but the end was left chromed.  The arm is identical to the '65-'66 Mustang arm but for the black paint.
See Here:
1963-1964 Ford Galaxie Turn Signal arm, Part#C3AZ-13305 :
http://www.ebay.com/itm/NOS-63-64-FORD-GALAXIE-TURN-SIGNAL-SWITCH-HANDLE-/191262406184?hash=item2c8820b628:g:830AAOSw7NNT0swh&vxp=mtr
:o)
Tony K.
« Last Edit: June 29, 2016, 01:18:41 AM by NEFaurora »
MCA#70001
Offline 196667Bob
« Reply #4 on: June 29, 2016, 12:45:44 AM »
Tony : I should have worded my reply better; I was not referring to the one pictured. I meant that the correct one should be the same on 1965 and 1966, and that part is a carryover from 1963 (C3AZ-).
Bob
MCA 04909
Offline NEFaurora
« Reply #5 on: June 29, 2016, 01:26:39 AM »
Well, That would make more sense...  ;)
:o)
Tony K.
MCA#70001
Offline 66RavenGTCoupeAgain
« Reply #6 on: June 30, 2016, 04:23:00 AM »
Thanks guys! ;D
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
