Author Topic: 67 fastback floor console  (Read 1030 times)
Offline socalgt
« on: May 26, 2016, 09:25:45 PM »
I know the length of the console is different for an a/c car......and I understand the sides are trimmed for convertible installation.  Are the side contours the same on both sides on an original fastback console?  It appears the left(driver's)side is trimmed more than the other, up to the seam line.
        Thanks...
« Last Edit: May 26, 2016, 10:45:18 PM by socalgt »
Offline C6ZZGT
Re: 67 fastback floor console
« Reply #1 on: May 27, 2016, 03:29:57 AM »
Are you thinking 65-66 when you say the length is different ? will be able to check our 67 for side trim on the weekend.
Brian
66 GT Coupe 6R07A143871 owned since 1983
40+ yr parts man , over 25 with Ford.
Offline socalgt
« Reply #2 on: May 27, 2016, 11:35:57 AM »
The consoles in '67 factory(in dash) a/c cars is cut shorter to allow for the configuration of the floor vents...at least that's my understanding and what I've seen.  The '65-'66 are shorter due to the "hang on" a/c unit.
« Reply #3 on: May 27, 2016, 12:00:11 PM »
        Thanks...
I do not believe they are identical, maybe post a picture of the area of concern with your question.
Offline Fastback2013
« Reply #4 on: May 27, 2016, 02:39:39 PM »
Here are 2 close ups of my center console...
It's a fastback but no A/C !
There is indeed a difference between drivers side and passengers side.
It appears that there was no trimming at the drivers side, but my car is a non A/C car offcourse
If you want dimensions or other angles of the center console, just ask  :)
hope that this is want you want/need,
Kind regards,
Jeroen
« Last Edit: May 27, 2016, 02:44:47 PM by Fastback2013 »
San Jose 7R02C1708xx
Fastback GTA
built on 01/12/1967
