Author Topic: 1968 rear axle 8" bearing, gasket and seal !?  (Read 1204 times)
Offline mhubert89
« on: May 25, 2016, 07:43:32 PM »
Hi ,
Trying to find somes parts to restore my rear axle 8" ! Where i can find all this parts and do you have parts number ? Like for seal 2 parts come out like 'wcy' , wich one i need ?
From this picture from my book .. I need
2 gasket, bearing, seal by side ! Just want to know where i can find all this stuff !! Look like CJ dont have everything for this ...
Mustang Fastback 1968
289, 4 speed
Re: 1968 rear axle 8" bearing, gasket and seal !?
« Reply #1 on: May 25, 2016, 08:37:19 PM »
google;  NAPA.  National Auto Parts Association. They have all your parts and their web site is user friendly.  Your gaskets are FPG 4828,you need two, and FPG 55001 you need two. The axle seals are NOS 13700 you need two.  The bearings are PGB  PRW207CCRA you need two. Double check and get confirmations on the parts and numbers.  DON'T JUST ASSUME I'AM CORRECT!   I usually buggar up at least one of the axle seals so you might want to get a couple extra.  Brian
« Last Edit: May 25, 2016, 11:10:22 PM by Brian Conway »
« Reply #2 on: May 25, 2016, 10:56:25 PM »
Not sure where your located but agree with Brian - I would start at my local regular (as compared to the places where the kid behind the counter worked at Big 5 or Taco Bell last week  ::) parts store.
Offline mhubert89
« Reply #3 on: May 25, 2016, 11:09:38 PM »
google;  NAPA.  National Auto Parts Association. They have all your parts and their web site is user friendly.  Your gaskets are FPG 4828,you need two, and FPG 55001 you need two. The axle seals are NOS 13700 you need two.  The bearings are PGB  PRW207CCRA you need two. Double check and get confirmationson for the parts and numbers.  DON'T JUST ASSUME I'AM CORRECT!   I usually buggar up at least one of the axle seals so you might want to get a couple extra.  Brian
Awesome !! Thanks , very appreciate !
Math
289, 4 speed
Offline mhubert89
« Reply #4 on: May 25, 2016, 11:11:38 PM »
Already did a couple store, in Canada its not easy like usa to find classic parts !
289, 4 speed
