Join us on Facebook: Search for 'ConcoursMustang' Private group!https://www.facebook.com/groups/concoursmustang/Indiana SAAC Fall Classic , French Lick, IN Oct 11-12http://www.insaac.org/SAAC National-Sanctioned Concours Event
I heard recently that with the Rally Pac, if the tach fails for any reason, and the car engine is running, it will stop because the ignition/coil circuit is wired through the tachometer. So a failure in the tach circuit shuts down the engine. Has anyone heard this, or is this just a myth? Thanks.
Is there a way to wire around this? Do we know for how long Ford used this system of running the ignition system through the tach? It sounds like a reproduction tach is a better choice for a Concours Driven car.
That is correct - it is not a myth. If you have a factory original Rally Pac (Faria style) the engine will shut off if the Rally Pac dies. To be more specific, the tach consists of two fundamental parts: a transformer on the input side and a gauge on the output side. If the transformer fails, then the gauge will read nothing and the signal to the coil will also fail and the engine will turn off. This is because the Faria style OEM/NOS Rally Pac is wired in series with the ignition circuit. Typically when an original Rally Pac dies it's due to the transformer failing.Note: There is an exception - gauge can fail but the transformer can still be operational and the car will run. PS - The reproduction Rally Pacs do not have this issue. Regards,Ron
If the tach fails and car won't start, it's not that hard to re-route the resistor wire back to the ignition switch plug.
