Author Topic: 69 boss 429 driveshaft markings  (Read 3484 times)
Offline bgp429
« on: May 23, 2016, 08:01:41 PM »
Would like to restore the driveshaft.  Have seen under body pictures with conflicting markings and different colors. There doesn't seem to be a source like there is for the Boss 302. Thanks
Re: 69 boss 429 driveshaft markings
« Reply #1 on: May 24, 2016, 02:03:29 AM »
Looked at my collection and I don't have enough solid data to recommend any markings. Good think is that their easy to add later ;)
Offline Sean C. Gearty
  • 1969 San Jose GT
« Reply #2 on: May 24, 2016, 07:41:18 PM »
When was your B9 assembled at Kar Kraft?
If your drive shaft is still in original condition, you can soak it in a rust solution that will bring out the original paint stripes on the shaft, and also the paint markings on the ends.
There are differences that I have found on 1969 original shafts.
« Last Edit: May 24, 2016, 07:44:41 PM by Sean C. Gearty »
Offline bgp429
« Reply #3 on: May 24, 2016, 09:48:26 PM »
Built Feb 69. I will try the rust remover this weekend but it was re-painted years ago and might have been bead blasted. Yes. I am finding out markings apparently varied. Either that or other well known restorers have differed opinions on what is correct.
  • 1969 San Jose GT
« Reply #4 on: May 25, 2016, 08:12:21 AM »
I have a very early KK February build 69 as well. I soaked the original drive shaft and took pictures and measurements during the process on where the stripes and paint daubs are on the ends. So my restoration is documented. I can send you the measurements when I get back home over the weekend.
I suggest you use a PVC pipe and cut out a section to set shaft into bath. you will need a large c-clamp to hold shaft down as it will float other wise. It will need to be rotated every hour over 24hrs. take pictures and mark the pvc area.
« Last Edit: May 25, 2016, 08:59:22 AM by Sean C. Gearty »
« Reply #5 on: May 25, 2016, 10:18:48 AM »
 Seans car is very early &had both engines in it at kk  so some features may be different than later production & his car is very original & bought from OO so its mostly unmolested .   Just don't go by the all the buildsheet color codes on a 69 b9.
  • 1969 San Jose GT
« Reply #6 on: May 26, 2016, 07:48:06 AM »
The build on his car at Dearborn is February 28th. The detail I shared would be too early for his car and would most
likely be different per Ed. Brian's B9 was released from KK March 12, 1969. Do we have anyone out there with
some drive shaft detail that Brian can work from? This is an early KK1400 #.
Offline bgp429
« Reply #7 on: May 26, 2016, 09:24:30 PM »
These cars seem to be hard to document. The build sheet code is LBRDWIG. Can any one confirm that this matches up with the driveshaft markings on an early car? Thanks
« Reply #8 on: May 27, 2016, 12:09:37 AM »
Believe that would have been the driveline markings for the 4 speed R code at Dearborn (and those colors match those cars) rather than the Boss 429 is was built into later from my understanding. Sure this will be corrected if the info is incorrect - I only had one Boss 9 in the past
BTW the "G" at the end is not part of the paint coding but the number that the driveline was assigned. May have indicated the bin or rack the driveline was in for the worker to find.
« Last Edit: May 27, 2016, 12:13:56 AM by J_Speegle »
