Author Topic: Radiator support color  (Read 1167 times)
Offline V8_bloke_28
« on: May 23, 2016, 04:35:10 AM »
Hi.
What color should the radiator support panel be on my 67 fastback San Jose mustang?
Is it a Matt black or semi gloss...?
Cheers.
Re: Radiator support color
« Reply #1 on: May 23, 2016, 08:58:19 AM »
The entire engine bay including the radiator support are semi gloss black.
« Reply #2 on: May 23, 2016, 01:29:17 PM »
+1
Offline preaction
« Reply #3 on: May 24, 2016, 12:18:48 AM »
Would this part fall under the rule that different shades of SGB  is a good thing ? ;)
Offline V8_bloke_28
« Reply #4 on: May 24, 2016, 08:05:37 AM »
Cheers
« Reply #5 on: May 24, 2016, 12:19:53 PM »
Simply put, yes. Some parts were dipped, others sprayed, as was the engine compartment. Without any source, I would (if possible) consider a range of 20 to 40 present semi-gloss black as a goal. Different manufactures of rattle can semi-gloss black might work. I have a couple of quarts of semi-gloss black I had specially mixed in the 40 percent range to make the difference obvious.
Offline preaction
« Reply #6 on: May 24, 2016, 09:15:42 PM »
Thanks Jim that's a good idea.
