Author Topic: 69/70 shelby - some fit mustang - pretty good list  (Read 1231 times)
Offline acman63
« on: May 17, 2016, 01:15:54 AM »
69/70 shelby parts- some fit Mustang as well.
Original antenna - nice used $750
Fiberglass Hood -  original  nice shape   $3000
nos  fiberglass hood skin lower with nos latch bracket  $1500
stripe kit reflective - all colors and models available  $175
NOS fastback side scoop  $100
convertible side scoops  $400  pr.   (1)  nos   (1)  nice used original undrilled
nos hood latch plate - riveted to hood  - $45
Hood Pins - assemblyline  - flat on bottom  rechromed    $300  pr.
Hood Pin plates - polished stainless -  glue to top of hood   $40  pr.
Hood Pins  lower plate - glues to bottom of hood .  $30  pr.
Original eyebrows -  rechromed  $1000  pr.
Original assemblyline  428 fan shroud  nice used   $1200
Original heater assembly $300
428 CJ  bare block 8J20  428 CJ Heads 8J and 8K dates  bare.  core parts - already oven baked, steelebrated with ss shot,  magna fluxed  for cracks  $3000  as a set
428 CJ  smog adjusting  and mount brackets   $250  nice shape  detailed dipped black paint
428 CJ  pulleys   non air  $300  pr,
Front bumper arms,  originals  $400 pr.
Foglight support bracket original steel  $400
Power Steering Pulley  80B  marked - original nice redone   $300
Battery Heat shield 27 series - original C7ZB-10A682-B  has a small chip out of one corner  but its a real one and very rare this size  $500
NOS convertible top bow  C9ZZ-7651274-A   $100
NOS CONVERTIBLE RH  2 piece  endcap - assemblylline   $300
428  PS  adjuster bracket  - nice pit free western part  restored dipped $100,
Steering Box   - correct SMB-K   dated .  restored bare metal box   inside and out  .  $450
Restored upper radiator bracket GT500   $75
70 Front spoiler - older reproduction  ABS Plastic like originals   $395
Fiberglass Headlight Buckets - restored to concours, pink finish . ready for that concours car $2000  pr.
axle tube - 2 hole  CJ style   primed and sanded.  primed again.  ready for paint  $600
428 starter autolite- restored inside and out    $350
Shock Tower upper brackets with washers - originals  redone   $150  pr.
Disc Brake Dust shields - nice originals, already detailed and dipped in black for that authentic look  $195  pr.
28 spline axles . restored,  cleaned , magna fluxed ,  checked for runout on flange,  replated studs,  new bearings  $300 pr.
31 spline axles.  . restored, cleaned,  magnafluxed  checked for runout on flange, replated studs,  new bearings , seal spacer.  ready to install .  $650  pr.
Coil spring Guards, Nice original western parts.  cleaned detailed painted batch paint $150  pr.
Convertible extended window cranks   , nice used   $75
Original front plastic splash shields - nice used  $150  pr.
Original assemblyline master cylinder, restored  $400
428 Rear brass intake fitting -2 piece, nice originals    $75
Disc Brake spindles - C8s  . cleaned,  magna fluxed,  detailed,  machined bare areas.  $300 pr.
Kelsey Hayes disc brake rotors - 2 piece , restored  $350  pr.
Pics available  inquire
920 434 3645   or jim@shelbyparts.com
« Last Edit: May 17, 2016, 03:42:26 PM by acman63 »
