Author Topic: Is this a factory GT?  (Read 5558 times)
Offline sgl66
Re: Is this a factory GT?
« Reply #15 on: May 13, 2016, 09:54:59 PM »
If the car was built in Metuchen, you may also get lucky and find a build sheet taped to the harness behind the gauges and/or in the springs under one of the seats. If you do find one, it would answer most of your questions.
1967 eight barrel
  • Guest
« Reply #16 on: May 13, 2016, 11:58:07 PM »
Just like Gray Market vehicles brought into the United States, which require inspection and vin verification, some being issued a riveted aluminum tag I have seen this done in Germany as well. So many of the Ford vins were weak stampings and by the time the engine compartment is primed and painted, it can be difficult to read the vin. Of course we all know that many have the battery side apron replaced because the battery rust them out. Many are rusted out at the top corner of the overlap, even those that were relegated to arid climates.  Being this is before '67. there should be three locations for the vin, if memory serves me correctly.
Left and right front aprons, right side under the fender, and the rear apron under the top edge of the fender.
Offline ChrisV289
« Reply #17 on: May 14, 2016, 12:09:12 AM »
Interior looks like it has been altered. If it was a factory GT the low profile rally pac would be installed. Also the interior blue looks funny with those colored seats.
2009 V6 Mustang Coupe
Offline sgl66
« Reply #18 on: May 14, 2016, 12:51:51 AM »
Rally pac was an option, not a standard GT piece from the factory.
Offline Josep
« Reply #19 on: May 14, 2016, 02:00:11 AM »
OK guys, thanks for your advices and comments. I will speak with my friend and explain what you all said.
Let's see what we find..
Josep
Offline Turnall
« Reply #20 on: May 14, 2016, 11:20:45 AM »
FYI, this is a buck tag.  This particular one is on my GT and you will note the PIO on the buck tag as was previously eluded to. Hope this helps...
I would caution that the presence of this tag does not make it a GT and the absence of it does does not mean it's not a GT.  As others have said, there are a bunch of things that have to be noted to make sure it's a GT.
Allen
« Last Edit: May 14, 2016, 11:35:03 AM by Turnall »
Offline rocket289k
« Reply #21 on: May 14, 2016, 11:53:21 AM »
Allen
Hi Allen - you should post the picture in the NJ buck tag retaining screw thread as well - http://www.concoursmustang.com/forum/index.php?topic=13681.0
Ron
Offline Turnall
« Reply #22 on: May 14, 2016, 12:04:24 PM »
Ron
Done.
Edit:  Because I can't spell my own name correctly...
Allen
« Last Edit: May 14, 2016, 04:38:45 PM by Turnall »
Offline Josep
« Reply #23 on: May 14, 2016, 02:50:38 PM »
Allen, yours it's a completely different buck tag from the one I've posed.
The one I showed here looks absolutely home-made.! But will investigate more.!
Josep
Offline WT8095
  • Dave Z.
« Reply #24 on: May 14, 2016, 03:03:37 PM »
That's Allen's point. The tag you showed is NOT a buck tag. The one you showed is a piece of scrap metal with a VIN number stamped into it, covering the car's actual VIN number. It may have been done because the original stamping was damaged or not legible. Or it may have been done to perpetrate a fraud. Either way, the car did NOT come from Ford with that tag on it.
Dave Z.
Offline Josep
« Reply #25 on: May 14, 2016, 03:08:47 PM »
+1. Completely agree with you Dave.!
Offline WT8095
  • Dave Z.
« Reply #26 on: May 14, 2016, 03:15:22 PM »
The worst-case scenario is that your friend purchased a stolen vehicle. It would be in his best interest to drill out the rivets and see what's underneath that tag (no harm is doing that, since the tag is not original). If the original VIN number has been altered or damaged, then the next step would be to look under the fenders as others have suggested. The GT/not GT issue is relatively unimportant compared to the possibility of possessing stolen property.
Dave Z.
Offline Josep
« Reply #27 on: May 14, 2016, 03:26:52 PM »
I will suggest my friend to inspect underneath the tag.
Documents are OK here but... who knows...
Josep
Offline NEFaurora
« Reply #28 on: May 14, 2016, 04:32:15 PM »
Yeah Josep....Lots of RED FLAGS with that car.  That riveted tag needs to come off to see what is stamped underneath it.  Who knows....The car could be stolen!!
:o)
Tony K.
MCA#70001
Offline Philma
« Reply #29 on: May 14, 2016, 04:37:09 PM »
As stated earlier interior colors are way off, could be picture quality. Deluxe interior had carpet on the kick panels these do not. Does not mean it isn't a GT but with the off colors and the missing carpet I'd question the Pony/deluxe option.
66 Fastback GT
6T09A16XXXX
Silver Blue
