Author Topic: 1967 vs 1968 hood hinges  (Read 2560 times)
« on: May 11, 2016, 08:26:35 PM »
Looking for input on my findings regarding 1967-68 hood hinges. Through the collective knowledge of the members of the Concours Mustang Forum, we know that mid-way in the 1968 model year they started using the notched or cut down upper section by the hood. Picture below shows 1967 hinge on the bottom, 1968 with trimmed section on top.
Both of these hinges are otherwise the same, same X mark on the rivets, and straight angle cut on the upper section.
Picture showing straight (1967-68 upper) and concave (1969-70 lower) on the upper bracket rear.
I spent some time inspecting my 1968 Cougars for a change over date. My fairly generous sample indicates that Dearborn made the change approximately the 3rd week in February. San Jose made the change between the 2nd and 4th week in March. I made these assumptions based on the scheduled build dates from the many door tags in my possession.
Re: 1967 vs 1968 hood hinges
« Reply #1 on: May 11, 2016, 11:21:49 PM »
So your finding hood hinges with the (side view) lower side rail (for lack of a better term) and a straigh back edge of the horizontal side/surface?
« Reply #2 on: May 12, 2016, 12:58:20 AM »
The Metuchen cars that I have seen seem to change around April.
« Reply #3 on: May 12, 2016, 03:02:04 PM »
So your finding hood hinges with the (side view) lower side rail (for lack of a better term) and a straight back edge of the horizontal side/surface?
Yes, here is a picture depicting both details.
Offline WT8095
  • Dave Z.
« Reply #4 on: May 12, 2016, 04:47:03 PM »
Also note the difference in shape of the rear link, and the amount of material around the rivet.
Dave Z.
Offline Murf
« Reply #5 on: May 12, 2016, 06:19:44 PM »
Our April 03 scheduled build date California Special ( SJ) car  has one of each hinge.  Had never noticed the difference until this thread came along.
John Murphy
« Reply #6 on: May 12, 2016, 07:10:20 PM »
Will see how many cars I have pictures of that area of the car and report back
NOTE: Believe that for participants in the survey that have hinge examples if they could include the stamping dates from the hinges it would likely provide some additional good info for the discussion. Just a thought ;)
« Last Edit: May 12, 2016, 07:18:45 PM by J_Speegle »
« Reply #7 on: May 12, 2016, 07:54:13 PM »
Looking for input on my findings regarding 1967-68 hood hinges. Through the collective knowledge of the members of the Concours Mustang Forum, we know that mid-way in the 1968 model year they started using the notched or cut down upper section by the hood. Picture below shows 1967 hinge on the bottom, 1968 with trimmed section on top........
I spent some time inspecting my 1968 Cougars for a change over date. ........................ San Jose made the change between the 2nd and 4th week in March. I made these assumptions based on the scheduled build dates from the many door tags in my possession.
Scott looking at what I have pictures and documentation of I found the following for the San Jose cars I have records of, after ignoring those that may have been replaced and  individual cars (orphans) lacking any support.
- The latest cars cars with the earlier style hinge was a group built (real build/completion dates) on May 15-16th 1968
- As for the earliest with the later version I don't have any real build dates but only VIN and the projected/guessed dates
Our Calif Special is one of the ones in the earlier style example group - unfortunately its not at home so can't provide the stamping dates from the hinges  :-X
8R15227x - 22C
8R15806x - 30D
8R16140x - 22C
Unfortunately this group above is not a very tight grouping (almost 10,000 numbers apart :( which makes it hard to determine anything from it alone IMHO
Offline 68NordicCat
« Reply #8 on: May 17, 2016, 10:18:48 PM »
Here is a later style pair with a stamp that looks like 84 303 or B4 303. Didn't catch the 8 or B until looking closely at the pics. Can just barely make out the 4 and the last 3 on one of the hinges. Not sure what date code that is but the different flange style is visible.
Dan
12/67 SJ Built 68 J code 4-spd Cougar
Offline WT8095
  • Dave Z.
« Reply #9 on: May 17, 2016, 10:43:27 PM »
Dan, second photo, that's definitely a "B" in front of the "4". And if you look really closely, you'll see there's another character in front of the "B". I can't make it out, but I think it could be a "9" or possibly an "8".
Dave Z.
Offline 68NordicCat
« Reply #10 on: May 18, 2016, 10:58:44 PM »
Yep I see that now. How do you read these codes?
Dan
