Author Topic: 67 Hood Turn Signal Lamp Harness, Early & Late  (Read 4442 times)
« on: May 11, 2016, 06:28:15 AM »
In attempting to get a correct harness for my '67, I was hoping to see a few close up shots of the early style hood turn light harness in a thread titled as such. I'm fairly sure it has been discussed elsewhere to some extent. Maybe even a re-direct link to another thread?
I should have the braided covering on the lower side where it would exit the lower hole in the hood.
Other threads have discussed the three (or more) hood designs used for the 67's at great length but less discussion about the details of the wiring harnesses used. Currently, my understanding is there are two versions...there may be more than two for all I know.
« Last Edit: May 11, 2016, 06:35:36 AM by 67gtasanjose »
Re: 67 Hood Turn Signal Lamp Harness, Early & Late
« Reply #1 on: May 11, 2016, 07:20:41 AM »
Link to other thread with MUCH discussion of the underside of hood details:
http://www.concoursmustang.com/forum/index.php?topic=5026.30
Reply #34 has a few good shots of the wiring with the braided covering.
I understand there were different bulb sockets too? Maybe not on the early turn signal harnesses (metal) but somewhere along the line going into the 68 style or later style they changed to plastic.
Then there are different turn lamps in the hoods. One without the lamp clamp and ones WTH the lamp clamp. When did that change over occur? (so many questions on these hoods, so few perfect answers)
Then, the louver housings switched to the longer studs somewhere along the line to accomodate the different wiring harness retainers (Yaaah! Yet another change!)
And to add to all of the confusion, different change-over dates at the three assembly dates (at least in how the wiring was affixed to or THROUGH the hood).
Maybe we can focus here mostly on the hood wiring harness for the turn signals itself and the correct bulb housings (metal or plastic), the correct length of the braided covering, the correct colors and type of wiring used in the assembly...things along those lines.
My primary interest at this time is to try and get an early version of the hood harness made available in reproduction world if at all possible...but I know other rabbit trails can be likely with so many running changes.
« Reply #2 on: May 11, 2016, 09:28:21 AM »
Richard I would think you car would be just the same as mine as they were only built days apart in the same plant.
Marty
« Reply #3 on: May 11, 2016, 09:37:49 AM »
Marty
Agreed.
Marty, I could use better images of the lower area and maybe some "tape measurements" to supply to Alloy Metal. Possibly include the diameter of the cloth sheathing, information along those lines might help a lot in getting an early style reproduction version going that might (did I say might) pass muster on the show field.
I have no objection to the thread also helping others determine what SHOULD be on their example too...I am sure, like my car, several things get replaced as the years flew by, using service parts to keep them on the road.
Always nice to make comparisons to "original examples" with close build data (like yours Marty is close to mine, at least on this detail)
Offline 196667Bob
« Reply #4 on: May 11, 2016, 10:36:21 AM »
Richard : It doesn't seem all that long ago that a lot of these items were covered in a previous thread, although I don't think the harness itself was addressed in any depth. One thing that did show up, along with the metal versus plastic light sockets, was that there were at least 3 different type clips used to attach the harness to the underside of the hood; rubber covered metal loop type that attached to the studs for the scoops; metal push on clips that pushed onto the sheet metal; and later 67 and 68 plastic loop clips that were screwed into the hood stiffening member (there may also have been a plastic clip that pushed into holes in the hood stiffening member).
I think any discussion of the Harnesses per se, should also include discussion of the sockets and wiring harness clips, as they seem to be related. I believe that John (67gta289) had quite a few pictures of the under hood harnesses and the different types of clips.
Although it doesn't help right now, I believe that I have originals of both the metal socket Harness and the plastic socket harnesses (as well as a current Repo) at our Colorado place. I can furnish pictures of them in several weeks when we go back there for the Summer.
Bob
MCA 04909
Offline 196667Bob
« Reply #5 on: May 11, 2016, 10:52:09 AM »
Looks like I do have a few pictures (although not very detailed) I had previously taken of both a Plastic socket Harness and a Metal Socket Harness. Note that neither have the braided portion. Also of interest is that the one with the metal sockets came from a '68 Hood (no holes for the "FORD" letters).
Bob
MCA 04909
« Reply #6 on: May 11, 2016, 05:36:56 PM »
Most of mine are from too great a distance to show detail and of course close ups are of worn aged part :(
But here are still a few that might provide some part of the puzzle for you guys working these details out
DEARBORN
7F1291xx
NJ
7T260409
7T2609xx
San Jose
7R1153xx
7R1390xx
7R1518xx
7R194xx hood
7R2391xx
« Reply #7 on: May 11, 2016, 06:48:47 PM »
I do know there are two versions of the GT headlight harness (disregarding tach and non-tach dash versions).  One has the built-in two prong plug for the hood lamp harness close to the firewall grommet and one that does not.  I believe the latter is the rarer version, and that requires a full harness from the headlamps to the hood lamps.  Is this part of what you're referring to as early and late turn signal lamp harnesses?
« Reply #8 on: May 11, 2016, 09:53:04 PM »
Nope, I was unaware of this.
« Reply #9 on: May 11, 2016, 10:35:57 PM »
Do you have example of the one piece harness? I have never seen any 67 or 68 with a one piece harness. It seems impractical.
« Reply #10 on: May 11, 2016, 10:59:11 PM »
I don't think I have an example.  I may be confused...I do know that there are two variants of the headlight harnesses, though.  Could one version be integral to the headlight harness and the other version not integral, but both mate to the hood turn signal harness?  It's been a while since I ran across this problem...I seem to remember I had to replace a customer's headlight harness with one that had the plug built in for the hood harness.  His original harness was too far gone for refurbishment, so I replaced it with one from my stock but it didn't come with that hood plug, not knowing that there were those with and without the hood plug.
I have at least three hood turn harnesses in various conditions, but really never compared them.  If any body wants, I can take photos for the group.  Some have the clips in place on the harness itself.
Offline 196667Bob
« Reply #11 on: May 12, 2016, 04:15:13 AM »
Yes, thanks. The pictures may prove to be "enlightening".
Bob
MCA 04909
« Reply #12 on: May 12, 2016, 07:07:41 AM »
With the several pictures shared so far in this thread and ones shared within the other thread http://www.concoursmustang.com/forum/index.php?topic=5026.30 I have noticed several variations. I might need to put together a file with VIN numbers to sort it out. Within the other thread, we already had significant discussion over the hood variations and I don't think there was ever a consensus reached mentioning any estimated change-over dates. At very least, there was about a 3-4 week difference of changing over at the different assembly plants.
WIRING DIFFERENCES NOTED SO FAR (please offer any variations you may have noticed to futher discuss)
* Metal Bulb Sockets or Plastic Bulb Sockets
* Cloth Braided Sheathing or Plastic Sheathing (some have been taped?)
* Attached to lower area of hood or not attached (seems the very early hoods with "no holes" were not attached)
* Attached to the cowl with ground wire or not attached (this was seen on several other variations
* Bulb Socket secured to lamp with screw & bracket or bulb simply snapped into the lamp (no screw or bracket)
A spreadsheet might help narrow these variations down but maybe we could finalize every variation noticed to date first?
Any help appreciated. This could be time consuming and I have a lot on my plate at the moment. I have already determined what I need to use on my example, I am simply trying to help establish a better guide for others to utilize when searching for components to install their wiring. Best case scenario, we could offer the results to a Harness Company to build a few more variations closer to original examples.
« Reply #13 on: May 12, 2016, 09:15:21 PM »
OK...here's what I have.  All three are different.  I really don't know what years these are from (except 67/68) let alone the dates or factories.
The first one is in great shape and has the cloth loom:
The next one has what appears to be a heat-shrink type tubing:
And the third one is missing all tape/loom, but has much different bulb sockets:
« Reply #14 on: May 12, 2016, 11:24:33 PM »
I can not say for certain but the last one may be a 69.
