Author Topic: 67 C6 transmission mount insulator  (Read 1244 times)
Offline preaction
« on: May 07, 2016, 05:11:00 PM »
Is this consistent with a assembly line part ?  Also would the insulator be semi gloss black ?
Re: 67 C6 transmission mount insulator
« Reply #1 on: May 07, 2016, 05:24:39 PM »
The correct, over time finish is early American rust. I would remove as much as possible without disturbing the rubber "flash" on the steel, then "protect" the metal's surface. Boeshield seems to be the current protectant of choice. Semi-gloss clear spray is another. Remember, the insulator is subject to a lot (two words) of road abuse.
« Reply #2 on: May 07, 2016, 05:49:27 PM »
I've often seen (in general not this specific application) a engineering number included on the insulator - can't say that all the suppliers did
The shape and design appears to be consistent with the application
On original ones I've got pictures of there does not appear to be paint on the insulator only on the top and or both of the metal sections
« Reply #3 on: May 07, 2016, 05:59:15 PM »
That is a big block only insulator for 67-70 C6 and 4 speed. C7 engineering number. +1 on appearance as Jeff described.
Offline preaction
« Reply #4 on: May 07, 2016, 08:42:19 PM »
Thank you.  ;)
Offline preaction
« Reply #5 on: May 07, 2016, 10:46:28 PM »
At first I didn't see this on the end.
« Reply #6 on: May 08, 2016, 05:06:25 PM »
