Author Topic: Lets decode some markings - 07/64 dearborn spindle  (Read 1948 times)
Offline JeffD
« on: May 05, 2016, 11:09:46 PM »
another for discussion.. passenger spindle after taking an evaporust bath - july 64 dearborn v8 with power steering
1st pic - behind where the spindle mounts to the front wheel area -red stripe and maybe something else
2nd pic - looks like it could be a white daub near where it bolts to the UCA
3rd pic - pink /white - heading towards the tie rod area...
thoughts? thanks in advance
Jeff Deaton
64 1/2 D-Code - in progress way too long....
Body   65A   Color M   Interior 56
Date 15G   DSO 24   Axle 1   Trans 6
Re: Lets decode some markings - 07/64 dearborn spindle
« Reply #1 on: May 06, 2016, 12:21:20 AM »
Never seen markings that large, that color or that general area as shown in #1
# 2 Upper arm near knuckle  seen that before
#3 Do have other examples around the same time and plant as your markings - typical though colors change depending on time period it would appear
Would help if you included the casting number from the spindles as another form of identification - just a though. I started doing this once I started collecting spindle info from spindles already detached from their original car
Offline JeffD
« Reply #2 on: May 06, 2016, 12:29:51 AM »
for pic 1 - i couldnnt tell if it was a single reddish stripe next to some other crap that hasnt washed off yet. i need to go through some older pics when stuff was together to see what i have.
i will get part/cast numbers and post them tomorrow... have a feeling if i get up now - iwill work through the night doing stuff and i need tomorrows work to pay for some of the parts i am ordering
Jeff Deaton
Offline JeffD
« Reply #3 on: May 06, 2016, 09:21:36 AM »
3
C4ZA
3107B
Jeff Deaton
« Reply #4 on: May 06, 2016, 05:11:42 PM »
Thanks - that info let me check my old hand written notes - unfortunately none with that number listed on those pages. So no additional examples to share
Offline petersixtfive
« Reply #5 on: May 06, 2016, 06:23:36 PM »
Could be mistaken but in pic 1 the spindle looks as if it has been repaired
Looks like a crack from top to bottom
Looks like a weld and then die grinder marks
Worth a closer look
« Reply #6 on: May 06, 2016, 08:07:37 PM »
Worth a closer look
Agreed it appears sometime has taken place. Scary thought though of using a welded spindle
Offline JeffD
« Reply #7 on: May 06, 2016, 10:18:38 PM »
thanks. I am still in the process of cleaning it up and will surely get looking at this more closely.
Jeff Deaton
