Author Topic: whitewall tire restoration  (Read 1971 times)
Offline acman63
« on: May 02, 2016, 12:13:41 PM »
Ive got some nos white stripe tires that have some staining in the whitewall , Ive tried Wesleys Blechewhite,  comet.  thinner  and it still is there.  any ideas appreciated!!
« Last Edit: May 02, 2016, 12:14:39 PM by carlite65 »
Offline suskeenwiske
  • 214-347-3628
Re: whitewall tire restoration
« Reply #1 on: May 02, 2016, 08:11:10 PM »
Comet and a stiff Nylon Brush always did it for me, but you've already tried that. The only other thing I used once in while, for really nasty spots, was medium to fine Steel Wool. Watch out for household cleaners as they may react with rubber; check the label, it may indicate if safe for automotive applications.
I wonder if Coker Tire or other Reproduction or Current Tire Manufacturers may be of help. Go on-line or call them, hopefully they'll have some suggestions.
All the best.
Ray
Ray
1965 Dearborn Coupe
6 Cylinder, AT, PB, PS, AC
Est. Build 23A
Offline preaction
« Reply #2 on: May 02, 2016, 11:13:52 PM »
Wesleys and a wire brush, but wesleys was sold and of course the product was changed and does not work as well as the old product. ;)
Offline outlawincorporated
  • Kangaroo Herder
« Reply #3 on: May 03, 2016, 09:08:07 AM »
JIM
I use soapy JEX (which is actually a steel wool pad with soap on the inside === you might need to google it) with great success on all kinds of stains/marks on new and old wsw tyres. This topic was also discussed on Hipo forum recently.
hope this helps.
regards.
PHILL BERESFORD.
MELBOURNE.
AUSTRALIA.
Offline CCP
« Reply #4 on: May 03, 2016, 09:27:40 AM »
This may sound crazy, but try using camping fuel. It has worked for me in the past.
1969 Fairlane Cobra formal roof drag pack
1968 Shelby GT500KR
6F08A-GT,a/c,4-sp.,ps,build date 16A. DSO 24 Jacksonville
« Reply #5 on: May 03, 2016, 01:55:36 PM »
As a last resort, tape up the tire and use a white vinyl dye that matches.
Offline dave6768
« Reply #6 on: May 03, 2016, 08:53:01 PM »
SOS pads and scrub, scrub, scrub.
« Reply #7 on: May 03, 2016, 10:50:17 PM »
+1 on what Charles said.
..but I would also use a stiff, fine short-wire, brass scrubby brush (linda like a BBQ brush) & beaching tire cleaners first. New tire stores often use a similar style wire brush to clean white walls, some of that blue crap tire manufacturers  use to protect the white walls is stubborn as hell.
