Author Topic: 67 a/c field & clutch  (Read 952 times)
Offline preaction
« on: May 01, 2016, 01:35:43 PM »
Im trying to assemble a working 67 a/c system and came across something Im not sure of, are both of these parts make up a working clutch ? These would be #7 and #10. it seems 7 was on my compressor but not #10 are both needed ?
Re: 67 a/c field & clutch
« Reply #1 on: May 01, 2016, 02:21:36 PM »
No both are not used on the same clutch. There are two different styles, one used the points and the other a inductive coil.
Marty
Offline preaction
« Reply #2 on: May 01, 2016, 02:58:17 PM »
Thanks Marty.  ;)
Offline preaction
« Reply #3 on: May 14, 2016, 11:13:37 AM »
Is it possible to change out worn carbons from a factory switch (#7 above ) or was the whole switch replaced ?
« Reply #4 on: May 14, 2016, 05:53:28 PM »
I suppose they could but most choose to get another brush switch . The C7 and C8 marked are still fairly common.
Offline preaction
« Reply #5 on: May 14, 2016, 07:26:16 PM »
Thanks Bob, I did find a good C7 part but  thought it would be wise to do preventative maintenance before installation. ;)
