Author Topic: 68 Dash brace bolt & rear axle bumper center bolt ??  (Read 4056 times)
Re: dash brace bolt & rear axle bumper center bolt ??
« Reply #15 on: May 01, 2016, 08:37:19 PM »
and nobody know about the center rear axle bump stop bolt ?? aybe just the lenght of the bolt can help me !!
Rear axle bumper - the book says 41196-S8 5/16-18X5/8 hex thread cutting.
There's a kit of 2 for 41196-S8 as F-1486. I don't know what comes in this kit. Head making will most likely not be as original.
I covered this in reply #3.
Offline Linc
  • 67 Fastback GT - Clearwater Aqua
« Reply #16 on: May 12, 2017, 12:01:46 PM »
In this thread it was said that AMK would have a kit for this dash brace. I need to put this in
my 67 Mustang.  What is the AMK kit number? I have searched their site and not found that kit yet.
      1967 Dearborn Fastback - Clearwater Aqua - 7F02A120xxx
       I am Linc....  What more could you possibly need to know.
« Reply #17 on: May 12, 2017, 01:04:46 PM »
There are some conflicting bits of information about your request.
Dash bracket to the dash - the book says 356780-S2 bolt, 5/16-18X3/4 pan head but I find nothing confirming this. I've found 378178-S2 bolt, 5/16-18X1.0 hex, disc (the same bolt used on the fenders) and 55736-S2 nut, 5/16-18 hex serrated (the same nut used in the spring shield, aka upper A-arm bumper bracket) used there.
Dash bracket to the firewall - 378735-S2 bolt, 5/16-18X3/4 hex, disc (a shorter version of 378178-S2), or I've found 378178-S2 itself, no separate nut, the bolt goes to a threaded insert.
AMK carries separately 378178-S2 and 55736-S2, I could not find a kit. There's a kit of 2 for 41196-S8 as F-1486. I don't know what comes in this kit. Head making will most likely not be as original.
I reread the thread and found no mention of a AMK kit for the dash brace.
Offline Linc
« Reply #18 on: May 12, 2017, 02:29:25 PM »
Quote
I had to order them as separate components from AMK. I talked to Max about this at AMK, and a kit should be forthcoming soon.
Sorry, I took this to mean a kit was in the works, and might be available now.   I will order the individual parts then based
on this thread.
Offline cmfuser01
« Reply #19 on: February 28, 2019, 06:50:22 PM »
Does anyone know if an AMK kit is available for the dash hardware and/or part numbers for same? I'm looking for the brace to dash face hardware (nut and bolt) specifically, I'm good on the brace to "cowl" hardware. My originals have turned up missing.
« Reply #20 on: February 28, 2019, 07:14:53 PM »
Try the library for part numbers under topic "Mustang Hardware Spreadsheet 67-68". Lots of answers there.
