Author Topic: 68 Dash brace bolt & rear axle bumper center bolt ??  (Read 4059 times)
Offline mhubert89
« on: April 29, 2016, 04:05:38 PM »
hi everyone !
try to find somes kit of bolt..can't find them in mustang store. can someone told me where i can buy them or which bolt i can go buy at a hardware store !!
looking for this two bolt kit :
dash brace and the rear bumper axle bolt ?
« Last Edit: February 28, 2019, 07:26:41 PM by J_Speegle »
Mustang Fastback 1968
289, 4 speed
Offline Fastback2013
Re: dash brace bolt & rear axle bumper center bolt ??
« Reply #1 on: April 29, 2016, 04:26:59 PM »
Good evening,
this is what I have for the first request..
hope this helps you further.
If you want additional information concerning measurements, please ask.
concerning the second question; I hope that others can tune in, my rear end is still in place  ;D
kind regards,
Jeroen
San Jose 7R02C1708xx
Fastback GTA
built on 01/12/1967
« Reply #2 on: April 29, 2016, 05:20:40 PM »
Good evening,
kind regards,
Jeroen
+1, can confirm visuals on Jereon's pictures for dash brace bolts...No help on where to obtain them though.
« Reply #3 on: April 29, 2016, 05:36:30 PM »
There are some conflicting bits of information about your request.
Dash bracket to the dash - the book says 356780-S2 bolt, 5/16-18X3/4 pan head but I find nothing confirming this. I've found 378178-S2 bolt, 5/16-18X1.0 hex, disc (the same bolt used on the fenders) and 55736-S2 nut, 5/16-18 hex serrated (the same nut used in the spring shield, aka upper A-arm bumper bracket) used there.
Dash bracket to the firewall - 378735-S2 bolt, 5/16-18X3/4 hex, disc (a shorter version of 378178-S2), or I've found 378178-S2 itself, no separate nut, the bolt goes to a threaded insert.
Rear axle bumper - the book says 41196-S8 5/16-18X5/8 hex thread cutting.
AMK carries separately 378178-S2 and 55736-S2, I could not find a kit. There's a kit of 2 for 41196-S8 as F-1486. I don't know what comes in this kit. Head making will most likely not be as original.
1967 eight barrel
  • Guest
« Reply #4 on: April 29, 2016, 08:40:01 PM »
+1.
 I had to order them as separate components from AMK. I talked to Max about this at AMK, and a kit should be forthcoming soon.
The hardware that is shown in the previous pictures is what came off of my Dec 66 build.  If you want the AMK numbers, advise. I have them on an AMK invoice.
The steel support was a light gray phosphate.
        -Keith
« Reply #5 on: April 30, 2016, 05:15:37 AM »
I still have some cleaning to do on my own parts ...
the steel bracket isn't a bare steel finish, but light gray phosphate?
Since mine is completely rusted, I couldn't tell what the original finish was.
And bolts are also phosphate and oil?
Thanks for the confirmation.
Kind regards,
Jeroen
Fastback GTA
built on 01/12/1967
« Reply #6 on: April 30, 2016, 04:28:25 PM »
They are normally have surface rust on them, I would be surprised if they were plated originally. Especially in such a protected area of the car. Have seen other years where you could tell they were possibly phosphated lightly but would not report that the color was "light"  Think the one in the top pictures has been cleaned or blasted ;)
They seem to be often in the same condition as the unplated and unpainted surfaces of the pedals and brackets around them
1967 eight barrel
  • Guest
« Reply #7 on: April 30, 2016, 05:55:30 PM »
Jeff,
Mine was phosphate, but VERY light. There was no rust inside the vehicle at all. Not even under the dash where we see light surface rust on the bare metal on most.
                                                    -Keith
« Reply #8 on: April 30, 2016, 07:11:04 PM »
Jeff,
Dug one out and can't see any coloration on it. Hmm
Wonder if I can find a do at home phosphate test
Too bad my friend the science teacher is retired and enjoying life. He use to be a great source at testing metals and platings for us in the past. Think he had some access at the "Lab"   ::)
« Last Edit: April 30, 2016, 07:18:17 PM by J_Speegle »
« Reply #9 on: April 30, 2016, 08:06:45 PM »
Taste test?
« Reply #10 on: April 30, 2016, 08:10:08 PM »
After 49 years -
That particular pan head screw, 356780-S2, is unique to the 67 dash bracket, no other Mustang application.
1967 eight barrel
  • Guest
« Reply #11 on: April 30, 2016, 09:16:03 PM »
Jim, I probably should have specified "Brace" However, the pan head on my '67 is a shorter version of the emergency brake mount at the dash. Most definitely phosphate.
        -Keith
« Reply #12 on: May 01, 2016, 12:20:37 AM »
Another characteristic of the brace screw, 356780-S2, is the diameter of the pan head - 0.670inch, also unique.
1967 eight barrel
  • Guest
« Reply #13 on: May 01, 2016, 01:27:42 AM »
Jim, have you been abusing the veneer calipers again?  ;D
                                                         -Keith
Offline mhubert89
« Reply #14 on: May 01, 2016, 07:13:44 PM »
oki.. first thanks to everyone who help me with this .. appreciate.
and nobody know about the center rear axle bump stop bolt ?? aybe just the lenght of the bolt can help me !!
in the same way, anybody can show me the lenght of the bolt for the rear tie down bracket ??
thanks again !
hard to put back a project when you receive everything dissambly in a box !!
« Last Edit: May 01, 2016, 07:22:24 PM by mhubert89 »
289, 4 speed
