Author Topic: 64-66 interior white.  (Read 1752 times)
1967 eight barrel
  • Guest
« on: April 27, 2016, 08:36:13 PM »
Does anyone have the current color code?
                                                   -Keith
Offline 66RavenGTCoupe
Re: 64-66 interior white.
« Reply #1 on: April 28, 2016, 03:29:39 AM »
I have PPG 8612 as the code. I'm fairly sure it got it from someone on here. Not sure of gloss level though if someone could help out? Was dash a matt finish and doors gloss?
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
1967 eight barrel
  • Guest
« Reply #2 on: April 28, 2016, 04:31:37 AM »
The color is semi-gloss. However, I want to make sure I don't end up with light parchment.
        -Keith
« Reply #3 on: April 28, 2016, 10:47:18 AM »
There were a couple different whites for 64.5 and 65, the earlier one is a bit creamy, the later more off-white.
The gloss should be matte/eggshell finish, should be just a little sheen to it.
I use PPG concept on interiors and use the SU4985 matting agent, mixed to eggshell specs from the tech sheet.
« Reply #4 on: April 28, 2016, 01:57:07 PM »
........... Was dash a matt finish and doors gloss?
Same guy painted both at the same time.
« Reply #5 on: April 28, 2016, 02:36:21 PM »
Let me toss a caveat in here - the ash tray front was painted elsewhere, and it seems to match.
1967 eight barrel
  • Guest
« Reply #6 on: April 29, 2016, 01:34:35 AM »
That would make sense Jim, considering the rivets that hold the door to the tray are silver and I doubt they painted them on the line and riveted them, they were likely done at a parts vendor for Ford.
