Author Topic: Warning flashers not flashing when I brake  (Read 1291 times)
Offline 66RavenGTCoupe
« on: April 26, 2016, 08:34:50 AM »
Hi Guys,
Well, as the title states my warning flashers stay on when I press the brake. All turn signals and all other lights work correctly. Any ideas on what may be the problem or where/how to look?
Thanks in advance,
Dan.
66 Metuchen, NJ  GT Coupe
Raven, Deluxe Black Int
6T07A1612##
BODY  COLOR   TRIM    DATE   DSO   AXLE  TRANS
    65B     A      66           02M     22          1     6
Buck Tag:
C/O  362  (Customer Order, Rotation Number)
5    M7 (Weld Bay 5, Bucked Dec 7)
PIO (Performance Image Option - GT)
Re: Warning flashers not flashing when I brake
« Reply #1 on: April 26, 2016, 08:54:54 AM »
THIS is normal on these cars  ;) While flashers are on and you step on the brake, you should have both front lights, both turn indicators and both brake lights ALL illuminated. Hazard flashers were a "modern feature" in the early Mustangs...not same as your modern versions of today.
« Last Edit: April 26, 2016, 08:58:04 AM by 67gtasanjose »
« Reply #2 on: April 26, 2016, 09:55:23 AM »
Thanks 67gtasanjose,
Was not looking forward to finding a short somewhere!
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
« Reply #3 on: April 26, 2016, 01:53:30 PM »
The E-flasher ties in the brake lights and left and right turn signals, all flashing.  When you step on the brake, power is now supplied to the system at all times and over-rides the flasher power input.  Perfectly normal and expected with that particular design.
« Reply #4 on: April 27, 2016, 08:05:59 PM »
Thanks Midlife. Was actually hoping you would chime in. ;)
6T07A1612##
    65B     A      66           02M     22          1     6
Buck Tag:
