Author Topic: Replacement for PPG DAR 9000  (Read 11221 times)
Re: Replacement for PPG DAR 9000
« Reply #15 on: September 23, 2016, 05:09:28 PM »
So what would be an accurate engine compartment paint for a metuchen car in 1969? I have a case of Krylon 1613 rattle can but body guy wants to spray it with a gun.
The 1613 is a good sheen to match a professional paint to . You can use any professional line and use flattener for a closer look. I think it is a mistake to paint such a large area with the Krylon. Ok for smaller items IMO but it still will not hold up to abuse. It that is not a concern then use it on the small parts. I do. The Krylon willnot hold up in engine compartment remotely well compared to a catalyzed paint. Heaven help you if you try and use a cleaner to remove dust and grime with Krylon. It is the only rattle can product I will use but it has limitations . Just my opinion.
Offline Raven R Code
  • 428CJ ~ 4 spd ~ 3L50
« Reply #16 on: September 25, 2016, 12:18:11 AM »
Check this thread out:
http://www.concoursmustang.com/forum/index.php?topic=13601.msg84000#msg84000
Ditzler DDL 9423 low gloss was available earlier this summer through my local PPG store. I bought 3 of the 6 they put in stock, special ordered from the factory like B Perkins said...and I'm reasonably sure I can get the 3 others if anyone wants them just show me the $$$money$$$
I'd be interested if the availability is there. Let me know.
Dave
Dave
~ Do it concours or don't do it.
« Reply #17 on: October 03, 2016, 07:07:19 AM »
Dave
LIMITED AVAILABILITY OF THIS DISCONTINUED LOW LUSTER PAINT.
Dave has expressed interest in ONE QUART
That leaves two more at this time.
I'm fairly sure I can get a "best deal possible" if I can get two more interested persons but as in all things, it's kind of an "act now" offer because as a "single quart" purchase I am sure there aren't any "deals" to be had with my paint store.
Offline Rusty
« Reply #18 on: November 22, 2016, 06:51:01 AM »
I'd be interested in the others if still available.
Rusty Maddox
1969 Mach 1, 390
Actual Build Date:  11/1/68
Assembly Plant:  Metuchen, NJ
VIN:  9T02S129xxx
 63C    T5     3A     05L      24       6       5
Body  Color  Trim  Date   D.S.O.  Axle  Trans.
Offline stangnet33
« Reply #19 on: November 27, 2016, 12:38:49 PM »
He kept the rest
